Power supply on DVX100 at DVinfo.net
Old March 29th, 2004, 12:47 AM   #1
Hi guys,
Question; I noticed how easy it may be for my DC cable to become damaged.
And I also noticed that there is a 7.2v port where the battery/DC cable goes into.
Instead of buying another DC cable as backup, can I just get a multi-adapter to plug into and power my DVX100?
If so, which multi-adapter at what specs? eg: volts, watts, amps...
Dushan Horvat is offline   Reply With Quote
Old March 29th, 2004, 11:19 AM   #2
All the gurus here and no one knows this one? :)
Old March 29th, 2004, 12:47 PM   #3
Dushan, just give it a little time and I'm sure someone will chime in. I'm not sure where you're located, but in my Eastern time zone you posted at 2am and that means between here and the west coast U.S., that lost about 10 hours to people sleeping.
Though I do know that some of the posters and Wranglers here only actually sleep once a week.
Imran Zaidi is offline   Reply With Quote
Old March 29th, 2004, 03:20 PM   #4
I'm in the Eastern time zone as well..up in Canada.
Yes, I am actually one of those who stay up all hours working :)
With any luck, someone will know...
Old March 30th, 2004, 04:34 PM   #5
I'm shocked no one knows this...??
Haven't any of you guys wondered what would happen if you damaged your DC cable adapter and your batteries ran out? What would you do then?
You'd have to have a replacement..and it's about $64 bucks for a DC replacement and you can't just buy that anywhere, like you could a multi-adapter.
That's why I'm asking if anyone knows this or has tried it as backup..
