#256 |
See http://www.dvinfo.net/conf/showthread.php?t=40688 and direct any reply there please -- thanks in advance,
#257 |
High Contrast Video With DVC30
I shot a video of kayaking and was not happy with the video. If I shot in auto it looked under exposed you could not see the peoples faces. If I opened it up for the paddlers, the falls was all washed out. I could not find a happy medium. check it out. your thoughts
http://media.putfile.com/Ohiopyle-Trailer-2007 |
#258 |
Bob,
Most of the clip looked exposed ok except for the parts going over the falls. Maybe just way to much white for the auto exposure to handle. Once they pass the falls the exposure seems to fall back into place. I have a DVC30 but have never had this problem as I never use the auto exposure feature but use manual zebra bars set at 100% for white water. Another suggestion is to use an ND filter. Since the DVC30 dosen't have a built in filter you can use a screw on type. This will allow you more lattitude with your exposure in bright high contrast situations. You can look at some white water shots over on my website for examples.
Mark videos: http://vimeo.com/channels/3523 Stock: http://www.pond5.com/artist/mark29 Last edited by Mark Williams; September 24th, 2007 at 04:30 AM. |
#259 | |
I agree,...use zebra...you should be fine. |
#260 |
Oops, my bad. There is one but I believe it is automatically engaged and you can't manually turn it off and on. At least I have never found the on/off switch.
Mark videos: http://vimeo.com/channels/3523 Stock: http://www.pond5.com/artist/mark29 |
#261 | |
Thanks guys I used a Hoya ND4 on all of the video around the falls. I always have this on to keep the f stop around f8 or less. I normally have my zebra bars on 80 and when shooting in manual exposed for the paddler, I will play with it the next time at 100. Someone also suggested trying a polarizer which i have. I will be testing all the above next week. I am thinking maybe the contrast range is just too great for the camera. I saw some stills from a high end Nikon 200 and they looked about the same with maybe a little more vibrant colors |
#262 |
IR lights & using nightshot
i use nightshot a lot +i use a light amplifier now this sounds expencive but in truth i did it on the cheep but its used in the context of the film in question,
night vision with the green hue great for the military look,not good at a wedding. But..using IR lights.the way you would normal photographic/videographic lighting and swtching the cam to B&W you get a well lit not so grainy image that most clients will be more than happy with.without using visable lighting. yes the eye problem gives away the fact you used IR but its a small price to pay for shots you would normally loose. as for wildlife videography its the only way to go, the BBC and Bill Oddie get passable results as do i . the cams i use are 1 SONY TRV 17E 800k pixel single CCD/NIGHTSHOT 2 PANASONIC VDR D300 3CCD 3.1 M pixel for day 3 SONY HDR UX3E 4 M pixel CMOS /NIGHTSHOT 4 A modified security cam connected to a night owl nightvision with a various sellection of second hand camera lenses from f2 basic wide angle to a 300mm @f5.. as for light and sound well ill post that later all seperated and all home made. |
#263 |
Take a look at this.
http://www.bhphotovideo.com/c/produc...att_Video.html
#264 | |
#265 |
Stripped tripod mount on base
The tripod screw hole is stripped. Has anyone had this problem and found a solution? The DVX camera's have 3rd party bases but I can't find a replacement base/tripod mount for the DVC 30.
#266 |
Pana DVC-30 for sale?
I have been shooting with the DVC30 for a few years now and love it. Don't have the bucks to move up to HD so I was thinking about picking up a second 30 as a B camera. Anyone out there thinking about selliing?
On a side note what is the opinion of the new Panasonic HMC-40 (I think it is?) looks like a nice possible move up to Hd for poor people like me! Thanks, Jeff
Created Design Video Video production for the common man |
#267 |
I have one myself and I love it!
Just saw one on Ebay for US$815 and another at a starting bid of $600.00. |
#268 |
You should put that over here as well:
http://www.dvinfo.net/conf/private-classifieds/ The HMC40 is definitely the long awaited successor to the DVC30. It’ll be competing with the JVC HM100. At the mommont I have a slight preference toward the HM100 for a few reasons including pure compatibility with both Windows and Mac and the fact that it records to both NTSC and PAL. I’m sure the HMC40 will have it’s own advantages and it’s too early to give a full comparison and my preference could change. You cant go wrong with either of them and I prefer them over the V1u for many, many reasons. |
#269 |
If you can find one, a used JVC GY-DV300U can be an incredible bargain for a SD camera. If you were to get one, you would likely wind up using it as your primary camera and the DVC30 as your B cam.
#270 |
Thanks for the replies. I have been watching eBay.
The 40 looks nice, but I have heard editing in AVCHD is a pain. I use Avid Liquid and would have to convert it before bringing it into my timeline. Jeff
