squeeze mode at DVinfo.net
Old February 26th, 2004, 09:29 AM   #1
squeeze mode
Hi Guys
has anybody tried to mask the lcd with tape to make it look like squeeze mode . You still get your 480 lines and then you chop it off in editing? I tried it and was beautiful. I have 100 and not the 100A.
Am i still getting 480lines ?
Please advice
Kumar
Harish Kumar is offline   Reply With Quote
Old February 26th, 2004, 11:29 AM   #2
Re: squeeze mode
<<<-- Originally posted by Harish Kumar : Hi Guys
Please advice
Thanks -->>>
If you crop in post you getting 480 less whatever you crop off.
-Rodger
Rodger Marjama
www.speedwing.net
Rodger Marjama is offline   Reply With Quote
Old February 26th, 2004, 12:43 PM   #3
thanks
that means if I use the letterbox inside the camera or mask the lcd it is the same thing ....???
Kumar
Old February 26th, 2004, 01:53 PM   #4
Barry Wan Kenobi
Basically, yes.
Old February 26th, 2004, 03:22 PM   #5
thanks guys
Kumar
Old February 26th, 2004, 10:05 PM   #6
DVX User
Its easier to mask than to in camera, as it give you a little leway on adjusting your headroom etc in post.
Jarred Land is offline   Reply With Quote
Old February 27th, 2004, 09:02 AM   #7
thanks Jarred
what do people mostly use to mask , any black tape????
Kumar
