anamorphic adapter at DVinfo.net
Old February 5th, 2004, 05:13 PM   #1
anamorphic adapter
So I've read most everything I could find about the differences b/w the 100 and the 100a and I've read about the anamorphic adapter as opposed to the on-camera 16:9. After wading through all of the info, I would like an opinion...
With the prices of the 100 falling due to the 100a, would I be better off getting a 100 plus an adapter or the 100a without an adapter and just use its digital squeeze? I would be looking at close to the same amount either way, just wondering other's opinions.
Nathan Nix
Nathan Nix is offline   Reply With Quote
Old February 5th, 2004, 05:43 PM   #2
Retired DV Info Net Almunus
It really depends on what you mean by "better off".
Old February 5th, 2004, 06:15 PM   #3
Personally, I can't stand to shoot in the squeeze mode. True, it's closer to a true 16:9 than just chopping the top and bottom in a crop mode but it's hard to judge exact image composition when it looks this way on the camera. I figure, if you're not going true 16:9, then just give it the chop. I just got my 100a and I had some time to play around with a 100 before I decided to go with the 100a. I think a few things sold me on it: the time lapse is great for sunsets etc, I would like to think panasonic addressed some of the "head wear" issues and using dv tapes other than their highest quality panny tapes (I use only sony as they've been tried and true for me) and the fact of the extra tweaks and improvements in the image processing. I figure, if I'm going to spend 3 grand, I want it to stay up to date for as long as possible. Now, if I had already purchased a 100 6 months ago, the A wouldn't bother me one bit, as the 100 is an amazing cam by itself, I just decided to put a little extra in. I guess it's important to evaluate realistically what you could be using this camera for. If your uses don't demand the extra perks, then don't get the A because the stock 100 is "revolutionarily" damn good.
Bryan Roberts is offline   Reply With Quote
Old February 9th, 2004, 06:42 PM   #4
I've got two of these anamorphic adapters and I've posted a lot about my observations in this forum before. I find that these adapters are difficult to focus for event or sports use. And remember that you MUST focus manually when using these adapters. Focusing has been impossible for me in full telephoto.
While I am able to retain 480 lines of resolution by using these lenses, I would not recommend them for event or field use. I'd also recommend making sure that you have a sharp external field monitor when using these lenses too.
Mike Morrell is offline   Reply With Quote
Old February 9th, 2004, 10:12 PM   #5
Just got the DVX100a today. I've been trying to get one since before they came out over 1-1/2 years ago, but something else always seemed to come first.
Gotta tell you I am overly impressed this camera and with squeeze mode. I did just a few minute test in the house, and I don't believe what I've seen is possible!!! -$3400 and I'm looking at FILM on my 19" monitor. Just amazing!
I will be shooting alot of fast pace actions shots and also nature videography so I am most likely going to get the Century 1.6 Tele-Converter and use squeeze mode. Obviously, just starting out with this camera, I'll know more as time moves along -- But for now...
I LOVE THIS CAMERA!!!
-Rodger
Rodger Marjama
www.speedwing.net
Rodger Marjama is offline   Reply With Quote
Old February 10th, 2004, 12:23 AM   #6
Just to clarify, the only use for the Squeeze mode is when using the anamorphic adapters correct? Thanks :)
Old February 10th, 2004, 10:08 AM   #7
Barry Wan Kenobi
No, quite the opposite. Squeeze mode is used INSTEAD of the anamorphic adapter.
Squeeze mode is a way to turn the 4:3 DVX camera into shooting 16:9. The anamorphic adapter is another way to turn the 4:3 DVX footage into 16:9.
Old February 19th, 2004, 01:31 PM   #8
Century 1.6 Tele-Converter?
This question is probably directed more to Rodger unless someone else also knows about it.
What exactly is the Century 1.6 Tele-Converter used for and how can it help my production?
Jason Epperson is offline   Reply With Quote
Old February 19th, 2004, 03:31 PM   #9
Re: Century 1.6 Tele-Converter?
Originally posted by Jason Epperson : This question is probably directed more to Rodger unless someone else also knows about it.
This converts the standard 4.5-45mm lens on the DVX100(A) to 36-72mm -- or about 2/3 more zoom. I'll need it to get a bit *closer in* on some of my nature work primarily but obviously it would benefit many other types of work as well.
Here's Century's link to the 1.6 Tele-Converter: http://www.centuryoptics.com/product..._tc/16x_tc.htm you can check out.
-Rodger
Rodger Marjama
www.speedwing.net
Old February 20th, 2004, 12:29 AM   #10
Barry Wan Kenobi
Notice that it doesn't say that it just gives you an overall longer zoom range, it says that it gives you 36-72mm. That means that they're saying you have an effective 2:1 zoom lens. Anything wider than about 36mm will start vignetting.
So it gives you longer maximum reach, but it's not something you can use in all circumstances -- basically a special-purpose lens.
Old February 20th, 2004, 04:59 PM   #11
Quick question, somewhat OT:
Has anyone compared the 16:9 squeeze mode on the 100 to the native 16:9mode on the PDX10?
Brandt Wilson is offline   Reply With Quote
Old February 20th, 2004, 10:38 PM   #12
i played with the squeeze mode and it looks amazing, but unless i'm going to be able to use my sony ntsc monitor that has 16:9 mode i can't figure out if it would be usable.
its a shame there isn't a way to show the squeeze mode unsqueezed on the onboard lcd.
the footage i have shot in the fake letterbox mode looks wonderful.
matthew
Matthew de Jongh is offline   Reply
