Mic in via RCA jacks not working... at DVinfo.net
Old April 16th, 2009, 04:00 PM   #1
How do I set my DVX100B to use a Wireless Mic? -- it uses a regular RCA/phono type connection. Normally, I'd use an XLR mic, but the interviewer wants to use the wireless lapel instead...
No matter which switches I flip, turn on or off, it won't work. Does the DVX100b accept line-in, or is that strictly for the VCR mode?
(yes, I checked to make sure the mic was working :-) )
Ted Bragg is offline   Reply With Quote
Old April 16th, 2009, 06:50 PM   #2
Ted,
In camera mode you have to plug the mic into one of the XLR inputs. It sounds like you need an adapter from the mic plug to XLR. The DVX does accept line in through the XLR inputs.
Ken Civian is offline   Reply With Quote
Old April 20th, 2009, 04:24 AM   #3
A wireless receiver that uses consumer lines levels on RCA for its output ???? That's really unusual, most are mic-level to either a mini jack or XLR. What make and model of wireless are you using?
Steve House is offline   Reply
