To ALC or not to ALC at DVinfo.net
Old January 25th, 2004, 05:59 PM   #1
Well, on this forum I've heard two takes on using ALC on the DVX100/A. Some say use it, others say don't.
I noticed the following link...
http://www.bealecorner.com/dvx100/a-...io-levels.html
And it suggests that the ALC doesn't affect audio levels at all until it gets into the danger range. Shouldn't that suggest that ALC is a win-win scenario? The exact quote from the above link is:
"...Below -5 dB ALC does not affect the audio response..."
Imran Zaidi is offline   Reply With Quote
Old January 25th, 2004, 07:36 PM   #2
I leave ALC on all of the time on my DVX100. From my tests it seems to really be a limiting compressor that only takes effect when the signal approaches 0dB. I did not use my previous camera, the PD-150's ALC, since it was an automatic gain control which attempted to adjust the gain to make everything have max volume.
Randall Campbell is offline   Reply With Quote
Old January 25th, 2004, 09:13 PM   #3
Barry Wan Kenobi
It seems you give up a little bit of dynamic range (i.e., clamping begins and maxxes out at -4.5db, vs. going to 0) in exchange for (hopefully) never getting blown-out distortion.
In other words, yes, basically a win-win.
Old January 26th, 2004, 07:11 PM   #4
Use it.
Peter J Alessandria is offline   Reply
