footage just a tad grainy at DVinfo.net
Old January 18th, 2004, 09:38 PM   #1
sometimes when im shooting i can notice that there is just a tab bit of grainyness in the footage. What should i do do make the picture more CRISP.
thanks
Mike Zorger is offline   Reply With Quote
Old January 18th, 2004, 09:55 PM   #2
Outer Circle
If you notice grain it means there's not enough light.
Old January 19th, 2004, 03:02 AM   #3
also lower your detail level...
dropping the Master ped to under -0 will also help
Peter Jefferson is offline   Reply With Quote
Old January 19th, 2004, 03:26 AM   #4
Please help. I see much noise in my night shots as well. Really appreciate if someone can tell me whether the noise level is normal. My original post was at http://www.dvinfo.net/conf/showthrea...154#post136154
Paul Leung is offline   Reply With Quote
Old January 19th, 2004, 01:37 PM   #5
so i should be the master ped to about -2 or so.
Old January 20th, 2004, 09:04 PM   #6
the only time i have ever seen any grainy footage was when it was dark and/or i tried the gain setting.
if it was dark when you saw this try opening up the shutter and the iris.
matthew
Matthew de Jongh is offline   Reply With Quote
Old January 26th, 2004, 07:07 AM   #7
yeah i had the gain up to hight. i fixed it this weekend. LOOKS GOOD NOW!!!
