New Hi-Def DVX100 clip at DVinfo.net
Old December 8th, 2003, 06:15 PM   #1
Barry Wan Kenobi
I think I posted the old DVX100 up-rezzed-to-HD vs. JVC HD1 clip here before, I'm not sure. Anyway, I've since figured out a much better way to up-rez, using S-Spline Pro.
Check out this clip:
http://66.78.26.9/~fiercely/DVXvsJVC/NewDVXvsJVC.mpg
That's the DVX100, up-rezzed to 1280 x 720 by S-Spline Pro, and then imported into Vegas side-by-side with the same clip as shot by the JVC HD1. Then I exported a new MainConcept 720/30P HD file (so in the DVX she'll be a little faster than in the HD1, but it was necessary in order to make a clip that the HD guys can download and play through their cameras).
If you try to play this back on your desktop you'll need a pretty fast computer to keep up the frame rate.
Old December 8th, 2003, 07:27 PM   #2
Wow- looks great. Never thought Up rezing would turn out results that looked that good!
Glen Elliott is offline   Reply With Quote
Old December 8th, 2003, 09:11 PM   #3
Which one is the DVX100 footage? Is it the first one or the second one?
Jaime Valles is offline   Reply With Quote
Old December 8th, 2003, 10:05 PM   #4
Barry Wan Kenobi
"Which one is the DVX100 footage? "
The one that looks good. ;)
(seriously, the DVX is the first clip, the one that has the S-Spline Pro watermark all over it. The JVC HD1 is the second clip.)
Old December 9th, 2003, 07:33 AM   #5
Awesome! Thanks Barry! I'm not familiar with that software though, was the process tedious?
Glenn Gipson is offline   Reply With Quote
Old December 9th, 2003, 08:30 AM   #6
Here I am, all the while thinking the 1st one was the JVC. Man 3ccds really help with color reproduction. The JVC's colors look flat and unsaturated.
Old December 9th, 2003, 08:53 AM   #7
I must be the only one not seeing the video- when I click the link, I get a new IE window and a spinning e-globe showing it's trying to get the mpg- but nothing comes down- anyone have any idea why?
(IE for Mac OSX)
Steve Nunez-New York City
www.stevenunez.com
Steve Nunez is offline   Reply With Quote
Old December 9th, 2003, 09:21 AM   #8
Takes a while to load- try right-clicking and choosing "save target as".
Old December 9th, 2003, 11:10 AM   #9
<<<-- Originally posted by Barry Green : "Which one is the DVX100 footage? "
(seriously, the DVX is the first clip, the one that has the S-Spline Pro watermark all over it. The JVC HD1 is the second clip.) -->>>
Yeah, that's what I thought, but I wanted to be sure. The first clip definitely looks better; I just keep getting more and more impressed with the DVX100. For the price, the image quality simply can't be beat. Thanks for this sample, Barry.
Old December 9th, 2003, 12:39 PM   #10
Barry, let be more specific about my question:
>>That's the DVX100, up-rezzed to 1280 x 720 by S-Spline Pro<<
Do you have to do this frame by frame? How long would this process take for 80 minutes worth of footage?
Old December 9th, 2003, 02:34 PM   #11
Barry Wan Kenobi
You do NOT have to do it frame-by-frame (thankfully!)
From your editing program you export your video as a series of stills (for 80 minutes' worth, you'll need quite a bit of space -- each frame is about a megabyte, and there's 115,200 frames in 80 minutes -- assuming 24 fps).
That'll create 115,200 frames on your hard disk, named something like Movie000001.tga, Movie000002.tga, etc.
You then open S-Spline Pro and tell it to batch-process those files. This will take a while. I think it was about 7 minutes for the three seconds that I did (on a P4 2.66Ghz). If you have a faster computer obviously it'll take less time. So it'll be hours and hours and hours of up-rezzing, my guess is it'd take around 8 days to do the up-rez. If you have multiple computers, obviously you could divide the task up between them, etc.
You'll also need about 500 mb of space for the up-rezzed files.
Old December 9th, 2003, 03:07 PM   #12
Thanks Barry! This is major news!
Old December 9th, 2003, 07:49 PM   #13
Membership Suspended
That's great! We finally get a chance to compare resolution and image quality. I tried up-rezzing DVX100 footage using S-Spline a while back but it was a slow and tedious process.
My workflow consisted of bringing the footage into After Effects, then applying the Magic Bullet de-artifacting filter to eliminate the 4:1:1 compression blocks, then exporting as uncompressed PNG files.
Then I would batch process the up-rez in S-Spline. Problem for me was I had no way to view it on a HDTV so the project was of little interest to me. Plus I was running on an 867Mhz G4 so it was painfully slow.
If you are looking into using this workflow for HD up-rez, then the best camera setting would be 24P/30P with the THIN setting. De-artifact (4:1:1) in After Effects. And use S-Spline for the up-rez.
Davi Dortas is offline   Reply With Quote
Old December 10th, 2003, 06:21 PM   #14
Presumably a PAL DVX100 would be even better?
Patrick
Patrick Bower is offline   Reply With Quote
Old December 10th, 2003, 07:16 PM   #15
yeah but not much.
Yang Wen is offline   Reply
