Editing 24pStandard vs 24pAdvanced at DVinfo.net
Old November 21st, 2003, 08:41 AM   #1
I recently ran into sloppy performance while editing footage shot in 24pStandard. The footage played back terrible in the preview window in Vegas. Granted I was using the default NTSC 29.97 template but why should that matter? ....Isn't 24pStandard still 29.97, I thought it's only 24pAdvanced that needs to be run with the 24p Template in Vegas to handle the advanced pull-down.
Thus so far I always though of it like this:
-24p Standard for the cinematic "look"
-24p Advanced for true 24p using 2-3-3-2 pulldown
Glen Elliott is offline   Reply With Quote
Old November 21st, 2003, 10:43 AM   #2
Space Hipster
Describe "sloppy" and "terrible" in more detail. 24p standard on a 29.97 timeline can introduce problems if you edit on judder frames (where one 24p frame is split across 2 frames).
stephen v2
www.insaturnsrings.com
Stephen van Vuuren is offline   Reply With Quote
Old November 21st, 2003, 10:44 AM   #3
Sloppy as in only reaching 9fps in the preview window.
Old November 21st, 2003, 10:46 AM   #4
Space Hipster
Probably due to edits on judder frames which require Vegas to render. The 24p standard template should resolve that.
stephen v2
Old November 23rd, 2003, 02:39 PM   #5
It was unedited source footage.
Old November 23rd, 2003, 02:42 PM   #6
Space Hipster
Not sure why - I've not seen that problem.
stephen v2
