green LASERS damage cameras?!? at DVinfo.net
Old November 12th, 2003, 02:18 AM   #1
A couple of days ago I filmed a huge Ibiza party with my DVX100. I was told by a few people that the party LASERS can damage the camera. I went and talked to the LASER technician at the party and he told me there was nothing to worry about. With his reassurance... i went and filmed!
Is that true? Can lasers really damage the camera? Was that dangerous what I did?
here’s that quick 20 second shot i did of the lasers. Copy past link...
www.illconcepts.com/rave.mpeg
Ozan Biron is offline   Reply With Quote
Old November 12th, 2003, 07:45 AM   #2
like any bright concentrated light, it MAY cause some damage... just like shooting into the sun without a UV filter...
next time use a filter..
Peter Jefferson is offline   Reply With Quote
Old November 12th, 2003, 01:54 PM   #3
sorry, cant help you on your question. But how did you create that ill concepts spinning action? I really like that affect!
Dan Lahav is offline   Reply With Quote
Old November 12th, 2003, 03:40 PM   #4
opsy... logo wasnt to be on there forgot to take it out! I animated the illconcepts LOGO in after effects... The sound effects took me awhile to do though... eh sound editing!
Old November 12th, 2003, 05:53 PM   #5
For what it's worth, I had a Canon L1 camcorder (back in the Hi-8 days, circa 1995) which had a few CCD pixels fried by a green laser at a rave party. Halfway through the tape, bingo, there it was. Be careful not to put the lens directly in the beam path -- stay a little above or below. Hope this helps,
Old November 12th, 2003, 06:00 PM   #6
I watched your clip and now I can't see anything! (Just kidding. But forget CCD's - I always wondered about the effect of laser light on the human eye.)
I thought your clip was cool. I too wondered about the spinning logo. Great effect! Also, what'd you use for the slow motion? It seemed pretty tight. Did you shoot 24 or 30p or 60i?
Peter J Alessandria is offline   Reply With Quote
Old November 13th, 2003, 12:31 AM   #7
For that party I filmed in regular mode... 60i!
For the "SMOOTH" slow motion effect ... i used the frame blending botton in after effects! simple as pie!
Old November 17th, 2003, 02:42 AM   #8
Depending on the Laser... they can be dangerous to cameras, pets and people...
I used to incorporate industrial laser shows into my corporate multimedia extravaganzas. We did a NYNEX show in New York inside and the New York Laser Safety Officer came into the ballroom (at the Vista in the base of the twin towers) and made sure that our beams were a certain distance above peoples heads and that all the beams were terminated with black wrap. She then took the keys to the laser board and returned the next day for the show. We were doing an outdoor show in Palm Springs and had to file with the FAA and they re-routed flights around the direction of our show for the small window of the showtime!! This experience has given me a great respect for the concentrated light...(I don't even like to have it hit me in the eye at the check out counter). Chris is right... try to avoid direct contact into the lens... the chips are so sensitive to light it could harm them. I can remember when (in the mid 70s) you could damage a camera simply by pointing it at a studio light. A streak of burn in would be on the chip. And the Sun? Fuggedabowdit!!
Todays cams are a lot more robust but Lasers are to be respected.
Multi-Media
Dale Anthony Smith is offline   Reply With Quote
Old November 17th, 2003, 06:14 AM   #9
Warden
In the seventies and most of the eighties all video cameras used tubes (not solid state chips like CCDs) that could be damaged by exposure to direct light. All of the consumer video cameras used tubes until the mid 80's when inexpensive CCD's became available. Tube continued in pro cameras until the late 80's.
I owned a repair company for close to ten years and we did warranty repairs for many major manufactures. During that time I never replaced a CCD for laser damage. I suppose it's possible, but highly unlikely.
Jeff Donald
Carpe Diem
Jeff Donald is offline   Reply
