24p questions - Page 3 at DVinfo.net
Old October 5th, 2002, 02:26 PM   #31
Warden
What is the vertical resolution of NTSC?
From the top of the screen to the bottom are 525 horizontal lines. In 1/60 of a second all the odd numbered (1, 3, 5, etc.) lines are drawn, then in the next 1/60 of a second all the even numbered lines (2, 4, 6, etc.). This is interlaced video. Each 1/60 is referred to as a field. Two fields make a frame, 1/30 of a second. hence 30 frames per second (actually 29.97, but that is another story).
Horizontal resolution is determined by many other factors depending on the format. Among the factors are bandwidth, lens quality, electrical components, tape quality etc.
I should also explain that the terms horizontal and vertical in this discussion are confusing. Vertical resolution is the horizontal lines and horizontal resolution is the vertical lines. The horizontal lines are counted vertically from top to bottom. Hence the term vertical resolution.
Jeff
Old October 5th, 2002, 10:11 PM   #32
Thank you, i think ive got it. Can someone now be so kind as to explain NTSC and HD to me....PLEASE
Ryan Wachter is offline   Reply With Quote
Old October 6th, 2002, 09:18 AM   #33
More infor than you ever wanted to know:
http://www.progressivescan.co.uk/index.html
http://rgb.com/Webpages/reftech/hiresconvert.html
http://scarlet.cs.nott.ac.uk/~tjb/pmm/pdf/mm6-02bw.pdf
http://bock.bushwick.com/hdtv_ppt/
Keith Luken is offline   Reply With Quote
Old October 6th, 2002, 02:54 PM   #34
beautiful! Thanks a lot!
Old October 6th, 2002, 03:40 PM   #35
canon xl1s PAL vs new Panasonic 24p
Can someone please shed some technical benefits, if any of this new camera. Should Canon users be worried about latest investment on a xl1s??
guerrapato is offline   Reply With Quote
Old October 6th, 2002, 05:00 PM   #36
how does a PAL xl1s interlaced stand?
Please explain if the 24p Panasonic will produce a superior noticeable image than the canon xl1s??
Old October 6th, 2002, 05:31 PM   #37
From what I was told, it creates a much noticed difference in that the panasonic give it a more convincing "film look"
Old October 6th, 2002, 05:41 PM   #38
Warden
The replacement for the XL1s is in the works. It has been since the XL1s was introduced. Video equipment follows a sort of evolutionary path. Now and then something revolutionary comes along. But not too often. Unlike some manufactures, Canon is usually pretty tight lipped about their new products.
Jeff
Old October 6th, 2002, 05:45 PM   #39
would you call it a better camera though??
Will a PAL 25p in the Canon be notiv=ceably inferior then the Panasonic?
Old October 6th, 2002, 05:54 PM   #40
Warden
It is really too early to say a great deal about the DVX100. Wait for a few reviews done with actual production cameras. Pre-release cameras are not always what the consumer gets. But for now the DVX100 will probably be the standard until the Sony or Canon make it to market.
Jeff
Old October 6th, 2002, 08:58 PM   #41
Outer Circle
The DVX is smaller and you can't change lenses. However, the resolution is higher and it shoots progressive scan instead of frame mode. They are different types of cams, although they share the same CCD size. Just pick one, depending which one tickles your fancy. But keep in mind that the XL1s is proven, the DVX is not (not yet anyway).
Old October 7th, 2002, 07:07 AM   #42
Images: 10
As an old still image photographer, it constantly amazes me how the hype and legend gets perpetuated about 24fps video. One of the things never mentioned is the fact that 24fps requires a slower shutter speed. As a result, several factors are introduced.
1-the aperture settings are usually smaller than 60fps
2-the shutter speed is slower
3-because of the slower shutter speed, motion blur is a lot more prevalent
Motion blur is something film-makers are used to and work around. Fast pans become more difficult...in fact, fast pans tend to stutter. I, personally, don't like this weakness of slower shutter speeds. The romantically inclined can't live without it...go figure.
Old October 7th, 2002, 10:28 AM   #43
You'll get a better image because:
a) Higher resolution 1280x720 pixels (vs. XL1s's 720x486)
b) True progressive frame. Canon XL1s frame mode is NOT true progressive.
c) Variable frame frate. You can (should be able to) shoot at 60FPS and slow it down the frame rate to 24 FPS (for slow motion) without the strobed look of most NLEs.
Jacques Mersereau
University of Michigan-Video Studio Manager
Jacques Mersereau is offline   Reply With Quote
Old October 13th, 2002, 11:23 AM   #44
interchangable lens vs 24p
What do yo think? Is the 24p worth loosing the option to change lenses? This would have to do with someone who is looking to do shorts and features for mostly festivals and internet.
Old October 13th, 2002, 11:28 AM   #45
Space Hipster
Without question for me. I'm working on my second short for festival circuit.
I sold my XL1 with 3X wide and 14X manual lens to get two of these.
The image is so much better than XL1 frame mode or XL1 deinterlaced in post. And wide and tele adaptors will arrive soon enough and won't affect the image near as much as the low res XL1 image does.
stephen v2
www.insaturnsrings.com
Stephen van Vuuren is offline   Reply
