Dropped Frames at DVinfo.net
Old October 14th, 2003, 05:44 PM   #1
Dropped Frames
Hey Everyone-
I just got my DVX100 on Friday and tested it out for about half an hour that night. Everything went well- so well in fact, that I decided to use it the next day as a secondary camera for a wedding.
Well, despite using the same tape type (brand new TDK DVM60), 5 minutes into recording I got the dreaded "X" in a red circle next to my time code that other people have reported in here (but of course is nowhere to be found in the manual). I played back my footage and there were horizontal lines everywhere. Good thing I still had my main camera with me. I tried using some Panasonic DVM60 tapes that my wife rushed out to get me, hoping that would solve the problem, but after 5 minutes again, the problem came back.
Why the heck is this happening to so many DVX100 users? I have had a GL1 for 4 years and nothing like this has EVER happened. Does anyone have a cure besides changing tape brand (which did not work for me) and cleaning the heads (this is a brand spanking new camera!!!!).
If you ask me, this is pretty ridiculous of an issue- it should never happen AND Panasonic should have listed the error icon IN THE MANUAL!
Comments? Suggestions?
Ted
Ted Banucci is offline   Reply With Quote
Old October 14th, 2003, 06:03 PM   #2
FWIW - I started by using SONY premium mini DV tapes in my DVX (which I used for years in my other camera without problem) and within two or three hours had clogged heads. I ran the cleaner tape, switched to the Panny MQ tapes and haven't had a problem since.
Peter J Alessandria is offline   Reply With Quote
Old October 14th, 2003, 07:35 PM   #3
Space Hipster
Ted:
It seems to be a tape brand/lube issue. I've only use the Panny MQ tape (on three different DVX100's - I had to sell the first two I bought) and had no issues.
Of course, it's only ancedontal, but I would try it.
stephen v2
www.insaturnsrings.com
Stephen van Vuuren is offline   Reply With Quote
Old October 14th, 2003, 11:38 PM   #4
Stephen-
Why'd you have to sell your first 2 DVX100's? Did the lube ruin them that much?
Old October 15th, 2003, 12:34 AM   #5
Space Hipster
Nothing wrong with cams - bought them (first that came into country and then I ran into severe financial problems a week later).
stephen v2
Old October 15th, 2003, 07:52 AM   #6
For some reason, I ALWAYS get dropped frames on the very first clip I record on a new tape. I stripe the tapes before using them and this happens regardless of the brand of tape I use.
It only happens with the very first segment on the tape. It ticks me off when I forget because the first thing I tape will always be ruined.
Does this happen to anyone else with a DVX100? It's very aggrevating.
Jim
Jim Quinlan is offline   Reply
