STD in viewfinder, what does it mean? at DVinfo.net
Old October 5th, 2003, 01:09 AM   #1
I was using the DVX for the first time.. I used it for 3 hours and it was fine.
It was still fine for the next 2 hours, but on the display where the initals STD.
What does it refer too?
And how to shut it off, or manipulate it?
thank u.
Matthew Kaplan is offline   Reply With Quote
Old October 5th, 2003, 05:58 AM   #2
RED Code Chef
Did you check the manual for it?
Rob Lohman, visuar@iname.com
Old October 5th, 2003, 07:58 AM   #3
If it is in the lower left hand corner of the display, then the initials 'STD' means the standard auto iris control is on, as opposed to 'SPOT' or 'BACK'
Check page 47 of the manual.
Christopher Go is offline   Reply
