Mixing TDK tapes with Fuji
I'm normally uses FUJI tapes, and I've ordered 25 tapes this week, but I've received 25 TDK tapes !!!! The reference is DV Digital Standard ME.
Is there a risk that I use these TDK in the DVX100? I know the Fuji are Dry, but don't know about these TDK. Thank in advance. |
Retired DV Info Net Almunus
Run a cleaning tape through the camera (per the usage directions supplied with the cleaner) before changing brands.
Lady X Films: A lady with a boring wardrobe...and a global mission. Hey, you don't have enough stuff! Buy with confidence from our sponsors. Hand-picked as the best in the business...Really! See some of my work one frame at a time: www.KenTanaka.com |
Outer Circle
Did you contact the dealer about the mistake?
Barry Wan Kenobi
Re: Mixing TDK tapes with Fuji
<<<-- Originally posted by Marc Martin : I know the Fuji are Dry, but don't know about these TDK.
Thank in advance. -->>> Not to stir up trouble, but -- who says Fuji tapes are dry? It's my understanding that only the Panasonic Master series use dry lube, all other brands are supposedly wet. |
#5 |
Outer Circle
No, Fuji miniDV is dry.
#6 |
Barry Wan Kenobi
Not to belabor the point, but -- where is the definitive answer? I searched Fuji's site and it said nothing about lubricant type.
I found this page: http://www.hosannaproductions.com/tips/minidv_lubricants.html where he claims to have spoken to the manufacturers and asked them, and even printed the name of who he spoke to. But, it lists all tape types as dry, EXCEPT Panasonic Master series, which he says is wet. And Panasonic Master series is supposed to be the only dry tape, according to Jan Crittenden -- she says Panasonic PQ's are definitely wet, MQ's are definitely dry, and are the only dry tapes out there. And the page says that Fuji's are identical to JVC tapes, including identical shells, part numbers and typefaces. |
#7 |
Barry,
You are quoting from a since-deleted thread in which Jan and others were quoted somewhat out of context. Please don't continue to propogate that, as it is not the complete story. There really is very little authoritative information available on the subject of tape lubrication. It tends to be a somewhat proprietary subject. The body of "knowledge" on this subject is largely anecdotal folklore passed along through forums like this. Much of it is baloney. Making sure that you run a cleaning tape when switching brands of tape and taking good care of your camera's tape transport are the best, and perhaps only, policies to avoid troubles.
#8 | |
I'm not sure that the TDK will be as good as the FUJI. I've read on forums that some people like TDK, others don't like, but all people seems to like FUJI. So I think I will return the TDK tapes. I will not take risks. |
#9 |
Barry Wan Kenobi
<<<-- Originally posted by Ken Tanaka : Barry,
You are quoting from a since-deleted thread in which Jan and others were quoted somewhat out of context. Please don't continue to propogate that, as it is not the complete story. -->>> Er, I don't know which thread you're referring to. I'm talking about direct e-mail conversations with Jan, where she says that the breakthrough differentation about Panasonic Master tapes is the new dry lubricant, which will not dry out because it's already dry, plus it provides for longer head life, and more replays without dropouts. She also said "There is only one brand that has dry, and that's Panasonic, the wet lubrications are everyone else." That's not out of context, that's out of the proverbial horse's mouth. So my question is, where is the substantiation of claims that other brands also use dry? |
#10 |
Outer Circle
Only a couple are "wet," while most are "dry." Maybe the Pana Master is just more "dry," like a "0" compared with a "1" in the sweetness scale for wines. :)
#11 |
Mark,
Which TDK tapes did you end up with? I've been using the TDK DVM 60 for the last three years even though I've upgraded to a better videocamera. I did have some dirty head issues with two cameras when I swapped playback of Sony and these TDK cassettes and didn't even know about tape lubricant issues. http://www.hosannaproductions.com/tips/minidv_lubricants.html doesn't list the type for TDK DVM60's. The box is unfilled. So, I'm guessing the TDK's are dry from personal experience. |
#12 | |
http://www.tdk.com.au/products/camcorder/minidv_dvm.htm On this site: http://www.dvfreak.com/tape.htm , you can read at the end of the page an "internal bulletin from TDK" saying: "Our MiniDV lubricant is similar to the Panasonic product and in normal use, mixing brands oftape should not cause any problems" But on this site http://www.hosannaproductions.com/ti...llbulletin.pdf, you can read the same exact text. Difficult to know the truth about tapes... |
#13 |
Outer Circle
"Similar" does not mean "the same." It means "similar." Similar, adj, alike in a general way but not exactly.---The Random House Dictionary.
