Alignment. My camera needs Alighnent. What is that? at DVinfo.net
Old May 12th, 2008, 11:23 AM   #1
A partner of mine sent his camera to a shop to fix a problem with the firewire port.
They recorded some footage and said that it needs some alignment which would be $150.00. Alignment? Dont cars need alignment? Next thing they'll be telling him his camera needs its carburetor lubed. -just kidding, but I am always weary of anyone telling me something needs fixed that i dont know about - like with cars, Casue i have no idea if its really important or not or you could just make anything up and ill have to go on your word.
>So, is this a legitimate thing? I asume yes, but id like to know what alignment is.
Tyson X
Tyson Persall is offline   Reply With Quote
Old May 12th, 2008, 12:24 PM   #2
the heads can and do go out of alignment which can cause all sorts of dropout problems. However it is not something that needs to be done on a regualr basis unless ther's something else going on inside. I've had the heads on both my 150 and 170 aligned-the 150 when the heads were replaced after about 1000 hours of tape thru them and the 170 when I had the chip replaced under the recall. I had to pay for the alignment as well as paying for the 150 to be R&Rd.
Again not something that usually needs to be done to soon but then it can and does happen.
Don
Old May 12th, 2008, 03:41 PM   #3
Cool, Thanks. This particular DVX100 has a LOT of hours on it so i guess ill do it.
Tyson X
Old May 12th, 2008, 10:00 PM   #4
He might be referring to a "software alignment" to bring the camera back up to spec. This can help anything from slight back focus issues to exposure variations. I was surprised at how extensively software controls many camera functions. The problem may not be completely mechanical in origin.
Hope this helps.
Ken
Ken Plotin is offline   Reply
