DV953 Red Cast - Green Sensor out? at DVinfo.net
Old January 1st, 2007, 02:44 PM   #1
Hi all,
Happy New Year!
I have a DV953 that I just took out of its bag after about a month of non-use. Previously there were no image issues.
When I turned it on today, it took several seconds for an image to come on. I thought I had left the lens cap, but that wasn't the case. When the image came up, it was very red/pink. White balancing didn't correct it. I aimed it at some blue objects, which appeared correctly. I aimed it at a green curtain, which did not. Luma is fine.
Is there a reset function I can use to force the camera to call up the green sensor, or does it sound like the sensor is no longer transmitting chroma detail? Or does it sound like the sensor at all?
Brandt
Brandt Wilson is offline   Reply With Quote
Old January 1st, 2007, 11:54 PM   #2
on the tape transport door, there is a tiny hole.. this is the reset switch.. it is for pal anyway..
if not do a search for the manual online and look for the reset switch
Peter Jefferson is offline   Reply With Quote
Old January 2nd, 2007, 08:33 PM   #3
Thanks, Peter I'll give that a try.
Old January 3rd, 2007, 07:21 AM   #4
Brandt,
Please see this.
Guy Bruner is offline   Reply With Quote
Old January 5th, 2007, 10:25 PM   #5
Thanks Guy. I was wondering about the recall. The RA paperwork is on its way from Panasonic.
