Tiffen MegaPlus Lenses (Converters) have arrived! at DVinfo.net
Old February 16th, 2003, 08:59 PM   #1
Hi, all! Check out this new range of Tele 2X and WideAngle 0.75 converters from Tiffen., available in 43mm!
Like Frank mentioned in another post, Tiffens are VALUE FOR MONEY. Especially if they live up to their quality claims with their new range - see http://www.tiffen.com/Header_page_Tiffen_digital.htm - click on the Press Release link and also the Fact Sheet link)
Hey, Frank, was it this new MegaPlus range that you tried out in the shop? Or was it the "old" ones? Were the old ones zoom through & multicoated?
Anybody tried them yet?
I emailed Tiffen regarding zoom through & multicoating, here's their reply:
Lori Hallas <lhallas@tiffen.com> wrote:
To: 'Steven Khong'
Subject: RE: Tiffen MegaPlus 43mm wideangle + tele questions
Date: Thu, 13 Feb 2003 09:28:27 -0500
Good Morning,
These lenses are coated for different elements.
You cannot "zoom through". This will in most cases cause vignetting.
I hope this information is helpful to you.
Sincerely,
Lori Hallas
The Tiffen Company
Customer Service Rep.
lhallas@tiffen.com
-----Original Message-----
Sent: Thursday, February 13, 2003 12:51 AM
To: techsupport@tiffen.com
Cc: s_khong2003@yahoo.com
Subject: Tiffen MegaPlus 43mm wideangle + tele questions
Hello! My name is Steven Khong, and I am interested in buying, but want to ask a few questions about your Tiffen MegaPlus 43mm wideangle & 2X telephoto.
1) Are the lenses multicoated for all the elements?
2) Can I "zoom through" the wideangle & telephoto? i.e. will I be able to use zoom from 0x, 1x up to through the whole range?
I have a Panasonic MX300, but I guess you can test on any Panasonic ND series (consumer range) to see if they are zoom through.
Thanks in advance!
Steven Khong is offline   Reply With Quote
Old February 16th, 2003, 09:55 PM   #2
Outer Circle
I tried the Tiffen's basic 43mm wide angle lens. It's .5 something (can't recall). The glass looked as good as Zeiss glass from my eyes---no aberations (from the edges), nor bubbles---just nice clean clear glass with a polished metal housing. Oh, and it zooms through pretty good, from what I could tell. (Yes, and filter threads too.)
I'll try to find out about the coatings.
Old February 17th, 2003, 05:51 PM   #3
Outer Circle
The Tiffen adaptors are multi-coated.
It seems that the Pana adaptors have the best zoom through - but no filter threads.
