Linear and circular polarizer at DVinfo.net
Old December 6th, 2002, 05:49 AM   #1
Outer Circle
Seems that both work on the MX cams, according to Panasonic.
Old December 8th, 2002, 07:23 PM   #2
Yes they are both OK, I have tested both, and I will say, "Buy the cheaper PL, the CIR-PL is not necessary". Again, at risk of being labeled "hypocritic", I am using CIR-PL. ;) Just because I bought it without test driving. These forums sure are useful!
Yow Cheong Hoe is offline   Reply With Quote
Old December 8th, 2002, 08:32 PM   #3
Outer Circle
That information took about 4 months to get from Pana, and after at least 10 e-mails.
I use circular ones, and they work fine. But it is good to know that circular ones aren't needed on these cams (and most cams, if not all).
