Kingston SD/512 - Page 2 at DVinfo.net
Old October 10th, 2004, 03:50 PM   #16
By the way, I found every time I press shot, it will take a while to shoot next photo.
Are you using the flash with each shot? That could explain the time lapse as the flash recharges. Well that and camcorders are not known for their speedy stills.
You might also want to try a lower resolution just to see if its in-camera processing causing the delay.
Tommy Haupfear is offline   Reply
