GS400 test pattern results - frame vs interlaced at DVinfo.net
Old September 19th, 2004, 07:08 PM   #1
Seeing the DVC30 thread about 50% loss in frame mode, I thought I'd do a test with the GS400 comparing interlaced to frame.
Test conditions were not great, hand held, indoors, auto focus, low light.
Despite that the most striking thing was that frame mode displayed just as good of vertical line resolution as interlaced. Horizontal res is very crisp. In fact most of the frames looked slightly better in frame mode than interlaced, but that could have been my shaky hand.
I would like to see someone else verify this. I am skeptical about the results, but I double checked the each clip on the timeline to make sure one was interlaced and one was progressive. They were.
http://users.adelphia.net/~jp1/normal.jpg
http://users.adelphia.net/~jp1/frame.jpg
Rokta Bija is offline   Reply With Quote
Old September 19th, 2004, 09:11 PM   #2
The vertical resolution in the frame mode chart looks like what you would expect from normal 60i video, around 360 lines. So it doesn't seem to be doing field doubling. But it probably isn't doing real progressive scan either, or we would see higher resolution than that....
Old September 19th, 2004, 09:45 PM   #3
Yes, that is consistent with my tests. There is no discernable difference between interlaced and frame mode.
Guy Bruner is offline   Reply With Quote
Old September 19th, 2004, 11:24 PM   #4
It is strange though that the DVC30 does show some loss, about what you would expect if Panasonic is still doing same green line pixel shifting described in that article they wrote. (linked to elsewhere on this forum)
Maybe the extra pixels in the 400's CCD's would explain some of it, but I don't see any loss at all, they look indentical.
Makes you wonder if they are doing frame mode differently now, like just combining the two fields without pixel shifting.
Old September 19th, 2004, 11:34 PM   #5
Oh, do most people use frame mode or interlaced mode? Sorry I'm new at this. What's the advantage and if I intend to create DVD later, which mode should I be using? Thanks.
Alvin Tan is offline   Reply With Quote
Old September 20th, 2004, 06:22 AM   #6
I suppose the GS400 might be doing some sort of deinterlacing in firmware, like we might do with software in post? Looking at some frames with motion in them might give a clue to this....
Old September 20th, 2004, 01:28 PM   #7
I've get similar results for PAL GS400
normal
frame
Mikhail
Mikhail Transact is offline   Reply With Quote
Old September 20th, 2004, 08:05 PM   #8
<<<-- Originally posted by Alvin Tan : Oh, do most people use frame mode or interlaced mode? Sorry I'm new at this. What's the advantage and if I intend to create DVD later, which mode should I be using? Thanks. -->>>
I use interlace mode for most work but when I'm filming fast-action footage with a fast shutter speed I use frame mode so that I can grab single images if I want to. The reason I use a fast shutter is to freeze the motion in each individual frame. It's much easier to get just the right action still this way -- rather than trying to hit the shutter at exactly the right moment in card-mode.
If you use interlace mode with high shutter speeds the results are not pretty when examined on a frame-by-frame basis in the face of rapid movement :-)
No problem too small to baffle this expert
Bruce Simpson is offline   Reply
