gs 400 info from panasonic australia at DVinfo.net
Old September 19th, 2004, 06:12 AM   #1
http://www.panasonic.com.au/catalogue/details.cfm?pcode=NV%2DGS400&pdiv=DVC3CCD&cat=2_1
this is web site with info
the following is an a 8 page brochure
http://www.panasonic.com.au/product_pdf/NV-GS400.pdf
above is a web site that gives alot more info than us site
re
in it gives more info on cinema mode
says something that it is 25 fps not clear wht it means though
any comments
Richard Seiler is offline   Reply With Quote
Old September 19th, 2004, 09:31 AM   #2
basically it runs thru the spec of the GS in PAL land..
very high end features with consumer brains and "ease of use" in mind.. much like the MX500..
its not progressive, its frame mode.. basically, it will capture the 2 fileds (per frame) and interpolate the 2 into one frame.
With that kind of resolution, there is no considerable loss in image quality.. but as its also runnign full res Widescreen, the results would be spectacular.. (better than the DVC30)
U know, come to think of it, im sure thered be someone ouit there with a firmware hack to get the GS to adjust Phasing, colour, filters gamma's, knee, master pededstals etc etc like the DVC..
i wish there was.. coz id seriously look at gettin afew of these.. the only reason i didnt get one, is coz i opted for another DVX.. (i coulda gotten 3 GS's )
one thing i havnt seen is teh GS compared to the DVC30 in low light.. cosnidering the CCD is larger, it shoudl theoretically be better.. but the manual controls in teh DVC are what make it what it is..
hmm.. at least i know if i want afew extra cams, i have these lil babies to consider :)
Peter Jefferson is offline   Reply With Quote
Old September 22nd, 2004, 08:51 PM   #3
image stablization
O.I.S. (Optical Image Stabiliser)
The O.I.S. helps assuring clear, beautiful pictures by compensating for any hand-shake that occurs as you shoot. Gyrosensors detect the amount and direction of hand-shake and a linear motor adjusts the lenses as needed to compensate.
MEGA O.I.S. (Optical Image Stabilizer)
The MEGA O.I.S. system takes O.I.S. technology a step further by adding a sensitivity selector. This allows MEGA O.I.S. to provide about twice*1 as much hand-shake correction when shooting still pictures as Std. O.I.S. provides with moving pictures.
this is what is listed in australian gs400
does american have optical stablization or electronic stablization
does anyone know
Old September 23rd, 2004, 05:34 AM   #4
optical..
mega is for still shot only
