PVDV 953 Audio at DVinfo.net
Old September 18th, 2004, 10:26 PM   #1
PVDV 953 Audio
Okay, so I have a PV-DV953 and I connect it to my computer through firewire, duh. I've never had audio problems or tweaked any of the settings. When the camera is in record mode I can hear the preview audio in my editor, but when the camera is in VCR mode I cannot hear audio at all, but I know its there, and I can hear it on my camera speaker. So it must be a camera setting. This is really really pissing me off. If anyone has any tips please let me know. Thanks for looking.
Riley Harmon is offline   Reply With Quote
Old September 19th, 2004, 12:47 AM   #2
Images: 1
It depends on what capture software you are using. Usually, the software doesn't play the audio during capture because it places more of a burden on the host which would result in dropped frames. You'll likely find that after you capture, the playback will contain the audio.
=gb=
Old September 19th, 2004, 10:05 AM   #3
Thats the thing, after Ive captured there is no audio. And my program has always previewed audio. :-( I just put a different tape in and it worked fine, but the tape i am trying to capture HAS audio! It plays on my tv fine. WTF!?!
Old September 19th, 2004, 01:34 PM   #4
It's not recorded in LP mode by any chance? Check your AV In/Out, A. Dub and DV Out settings on the VCR Recording menu. They should be set to AV Out/Phones, Off and Off, respectively. Also, try resetting the cam.
Guy Bruner is offline   Reply With Quote
Old September 23rd, 2004, 07:52 AM   #5
Try to do a capture with WinDV and see what happens.
Carlos
Carlos E. Martinez is offline   Reply
