pani manual shutter /slaved aperture at DVinfo.net
Old August 3rd, 2004, 09:50 PM   #1
Hey all
I know I can manuall set the shutter speed and fstop in the menu. I also know that when I change the shutter speed the camera automatically adjusts the aperture to the right size. so...
If I zoom in on a grey card, then adjust my shutter speed to what I want- Will the resulting aperture/fstop remain constant until I either reset the camera or readjust the shutter or will the aperture cotinually change as I film?
Quick followup- How good is the pani light meter at doing this? I have a GS100.
Thanks!!
Andrew McNeeley is offline   Reply With Quote
Old August 4th, 2004, 02:50 AM   #2
Outer Circle
I assume the aperture/iris opening will change, if the light changes---that includes with moving and zooming, because the light will change. Am I wrong?
Old August 4th, 2004, 02:40 PM   #3
I've done some research on the net...its hard when the manual is in japanese and pani manuals tend to suck anyway. LOL
There is a button called AE Lock which allows someone to keep a fixed fstop & shutter speed.
SO, I guess I could zoom in on a grey card, then set shutter to 1/60th (or whatever), wait for the Fstop to adjust automatically, and then lock it into place.
Which brings me back to question #2- Do the higher end panasonic models do a good job of calculating fstop at a given shutter speed?
Old August 4th, 2004, 06:23 PM   #4
You should experiment adjusting the iris opening/gain manually after you set the shutter speed.
Allan Rejoso is offline   Reply With Quote
Old August 5th, 2004, 05:18 AM   #5
Outer Circle
Andrew, don't search the web. Search right here on this forum and the PDX and VX2100 forums. In your search, put in Tom Hardwick. Tom has explained this a number of times.
