Elementary questions on UV filter at DVinfo.net
Old July 15th, 2004, 03:17 AM   #1
Hi,
To protect, my mx500 leica lenses, I would buy a UV filter. I have a step-up ring 43-55 so I think will be easy find one...but I would to know, wich is the difference using or not using a UV filter? Can I use it in indoor shot, or only for outdoor? Will I have a light loss? So, could anyone explain me the advantages and disadvantages of this device?
Thanks so much!
Marco
Marco Mezzalana is offline   Reply With Quote
Old July 15th, 2004, 03:50 AM   #2
I think the biggest advantage is the protection of your cam's glass and you can definitely use it indoors. To be honest I can't tell much difference with the filter on or off but the peace of mind about lens protection keeps the filter screwed on tight (not too tight of course!).
Tommy Haupfear is offline   Reply With Quote
Old July 15th, 2004, 05:53 AM   #3
A good UV filter also reduces flaring and cuts off the UV excess light, giving slightly richer colour (not as good as a polariser, but given 99.99% transmitivity...). Sure there is a little little little light loss, but the 'sacrificial' protection is certainly good. Especially when you are shooting children who'll suddenly poke a toy at the lens!
Wow, you have a 43 to 55 step up! I am currently stepping up 43-52 than 52-55. May I ask were you got that 43 - 55 and at what price?
Cam: Panasonic MX350EN, SOLD my MX8EN
Mac: G3 400MHz PowerBook, 256 MB, OS 9
PC: Pentium 4 2800MHz, 512 MB, WindowsXP
SW: iMovie, Final Cut Pro, Adobe Premiere, Ulead Video Studio, various little utilities
Yow Cheong Hoe is offline   Reply With Quote
Old July 15th, 2004, 06:24 AM   #4
If you are worried about even the slightest effect of a UV filter and your main purpose is simply to protect the front glass, then just use an MC (multi-coated) protector. It's just a clear filter.
Allan Rejoso is offline   Reply With Quote
Old July 15th, 2004, 07:33 AM   #5
the stepup ring?It's very simple I purchased it at B&H...Ok I think it's the best choice for me...I think I bring with me the cam to test the filter...
thanks...
Old July 15th, 2004, 08:28 AM   #6
You do not need a UV filter unless you are high in the mountains and shooting outside where UV rays are more prevalent. There is no UV on interior shots when there is no sun. UV is filtered by the atmosphere in lower elevations.
Some of us don't own a UV filter or don't use it. A "protective" filter can be used if you believe there will be some bumping around the lens or, perhaps, dirt in the air. Otherwise your lens cap does the job just fine.
Rob Belics is offline   Reply With Quote
Old July 15th, 2004, 08:55 AM   #7
Allan, thanks for reminding me about the MC protector. I'll be going with one of these over a UV filter on my upcoming cam.
Rob, I always like to have something in front of my lens but thats probably because I have a two year old at home. :) I agree that for the most part a UV filter isn't needed.
Old July 17th, 2004, 06:35 AM   #8
Ok, the UV filter do its work: protect the lenses..I've test it today!
I would to say, If I would shot sunset or the down, wich filter I have to use?
With my mx500 when the sun come in the visible area, its appers with dirty conturs. How can I do to obtain the clear sun circle like classic africaans sunset?
thanks...
Old July 17th, 2004, 07:40 AM   #9
You can't unless you ND down plenty (+4 two pieces maybe). That's because the CCD will overload with such a bright target and bleed, smear, 'UFO' etc. By the time you ND enough to shoot the sun, everything else will be pitch black.
In any case, I wouldn't recommend keeping the cam pointed at the sun directly for more than a short few seconds, I fear that the image might get burnt in (CCD damage).
Old July 17th, 2004, 07:46 AM   #10
hmm I think that...Anyway, I never point camera to the sun when its high in the sky...only when I can see it with naked eyes, and only for few time...
