GS-400 battery and other accessories at DVinfo.net
Old July 8th, 2004, 07:23 AM   #1
Hi !
I was wondering what sort of battery the GS-400 will use ? Is there a new battery type for this camcorder ?
I think I heard somewhere that Panasonic is coming out with a new wide angle converter but I assume any old 43mm wide angle converter will still work with the GS-400 ?
Camcorders are expensive enough, so I'm hoping to be able to use some old accessories with the GS-400 for a while :)
Cheers,
Espen
Espen Egeland is offline   Reply With Quote
Old July 9th, 2004, 01:45 AM   #2
Seems like I may be answering my own question :)
Tony Leung posted this picture in another thread :
http://www.pconline.com.cn/market/hk/xinpin/dv/0407/pic/gs400w10.jpg
It seems that the GS-400 comes with cga-du14 battery. Isn't this the same battery type that the other GS camcorders use ?
Old July 9th, 2004, 05:39 AM   #3
My GS100 uses a similar looking battery and has the model # of VW-VBD140. Its also rated at 7.2v and 1360mAh and has the same positive/negative pin configuration as the photo you linked to.
I'd say yes.
Tommy Haupfear is offline   Reply With Quote
Old July 9th, 2004, 07:30 AM   #4
Yes, the GS400 shares the same batt as the GS100/200/120/70/55 and even that of the DVD camcorder.
Pany is offering a new 43mm teleconverter lens in line with the GS400 release.
Your 43mm wideconverter lens should attach properly to the front thread of the GS400.
Allan Rejoso is offline   Reply
