best filter for gs400? at DVinfo.net
Old May 17th, 2004, 05:19 PM   #1
Which is the best filter for the gs400? Must I also get a rubber tube for the big lens to block sun light? How much is that thing?
Tom E Young is offline   Reply With Quote
Old May 17th, 2004, 07:24 PM   #2
Outer Circle
Just screw any UV on the cam to protect the lens along with a screw-on lens hood, that is if the GS400 doesn't already come with a hood. My MX300 came with a rubber lens hood.
Old May 19th, 2004, 05:21 PM   #3
I will buy any filter I find. Thank you for advise.
Old May 19th, 2004, 07:59 PM   #4
Outer Circle
I had a Heliopan UV for my MX3, a slim one, and it cased flaring. I have Cokin UV's now on all my 3 cams and they work just fine. Expensive doesn't mean it's better. My Nikon UV's seem good as well, but I don't think they make them in the 37mm and 43mm size. I have some Hoya's, but not any UV's from what I can recall. They work fine.
Old May 20th, 2004, 10:55 AM   #5
For me the best filter for G400 will be wideangle attachment lens :-)
Mikhail
Mikhail Transact is offline   Reply With Quote
Old May 20th, 2004, 04:20 PM   #6
Outer Circle
Good one, but which one? :-))
Old May 20th, 2004, 11:51 PM   #7
I don't know yet. I can't make choice witout trying and testing before.
Mikhail
Old May 20th, 2004, 11:56 PM   #8
Outer Circle
Maybe the Raynox HD6600pro? That's the one Tom seems to prefer for his 43mm threaded MX300...if he ever puts it back together. :-))
Old May 21st, 2004, 02:17 AM   #9
IMO no matter which thread is attachment. Conversion rings gives ability for various thread size. I has practices with using step-down ring without any vignetting.
Therefore attachment for GS400 may be 52,49 or even (may be) 37 mm threaded.
Mikhail
Old May 21st, 2004, 02:50 AM   #10
Outer Circle
Not really. There's a good chance a 37mm--->43mm will have vignetting with the iris wide open. It's better to go larger to smaller.
Old May 21st, 2004, 04:08 AM   #11
For example, have a look to JVC GR-DV500:
http://www.videomax.ru/images/jvc_gr-dv500.jpg
It has 52mm screw mount. However, lens size is much less then filter thread and field of view is far narrow in tape mode. Consequently, there is no problem to use step-down ring up to 43 mm.
By the way iris don't affects to field of view.
Only tests can show is it true for GS400 or not.
Mikhail
Old May 21st, 2004, 04:14 AM   #12
Outer Circle
I can't argue with that. :-))
