is gs400 to big for run and gun? at DVinfo.net
Old May 15th, 2004, 04:19 PM   #1
I see gs400 is bigger then other Panasonic video camcorders. Still good for run and gun or to big?
Tom E Young is offline   Reply With Quote
Old May 15th, 2004, 06:40 PM   #2
Outer Circle
It's not too big but we don't know if it's easy to grip such as a MX5000/PV-DV953---the MX300 is not easy, the ridge is too small for its puffed plastic body, PV-DV601 like. This isn't a bad thing, though.
You keep mentioning, run n gun. As I said, I don't run. But you ever considered, peek n run? Or, peeka-boo? See here:
http://www.dvinfo.net/conf/showthrea...threadid=25690
Frank Granovski is offline   Reply
