MX8000 Mamba II?? at DVinfo.net
Old April 23rd, 2004, 05:45 PM   #1
MX8000 Mamba II??
What camcorder is Chuckmeister refering to? GS400?
http://www.supervideo.com/panason.htm
Young Lee is offline   Reply With Quote
Old April 23rd, 2004, 06:34 PM   #2
Outer Circle
I have no idea. At least it's got a Hoya lens hood on it. :-))
Old April 23rd, 2004, 07:55 PM   #3
That's not a pic of what Chuckmeister is referring to. If I'm not mistaken, that's a photo of a gs100k owned by a friend of the Chuckmeister - the one who found a way to add a filter and hood to the unthreaded Pana WA lens that requires good glue and very steady hands. Supervideo touts it elsewhere on his site as the English Super Mamba or some similar sobriquet.
Patricia Kim is offline   Reply With Quote
Old April 23rd, 2004, 07:59 PM   #4
Outer Circle
Yup. I always suggested if you need a filter on your Panasonical adaptor, get a UV filter, take the glass out and then glue the glassless filter on using Crazy Glue or Super Glue. :-))
Old April 23rd, 2004, 10:52 PM   #5
Chucky must have got a few things wrong =)
on one side he says "2005 MX8000 BLACK MAMBA arrives July 4th"
which is GS400
on other he gives the colourful name .. "White Lightning" of the so called "(ie PAL MX700)"... and the specs of..:
again GS400
so go figure
http://www.supervideo.com/WhiteLightning.htm
George Beck is offline   Reply
