GS 100 Batteries / filter size at DVinfo.net
Old March 21st, 2004, 11:40 PM   #1
Hi you all
just two quick questions , what is the US model # battery for the GS -100.. and any ideas about good places/ prices ... does B&H carry them> ?
what is the filter size.. 43mm? that is a guess.
by the way... I LOVE the GS-100K . THANK YOU THANK YOU ALLAN, FRANK.
would have never purchased it if it were not for Frank's initial information, and Allan's incredible knowledge and service. I miss my VX2000 (especially in low light) but this camera is what i need right now.. I carry it with me everywhere i go and am actually shooting again, baby, teaching job and all. It truly fits in a stroller!
This site and the people on it have truly shown me the power of the web!
Kristin
Kristin Tripp Caldwell is offline   Reply With Quote
Old March 22nd, 2004, 12:22 AM   #2
Outer Circle
Thanks, Kristin. Yes, the filter size is 43mm.
Regarding the US model batteries, I'll do a seach here later, but I'm sure one of our helpful members will jump in with this information by then. Okay, I copied these 2 posts:
GS100 and GS70 use exactly the same battery. Model no. in the US is not the same as in Jap but if the CGA-DU21 works for the GS70, then its gonna work fine for the GS100. Just get the biggest on-cam batt that fits. Have you checked the batt seller in HK? For equivalent batteries, try to check sabahoceanic.com ---Allan.
I bought the du-21 bat from B&H along with some tapes and a bag. works fine and should last longer than the one supplied. ---Dave
If you hit the search button, type in, GS100 batteries, specify the MX Forum, you'll get tons of battery threads/posts.
Old March 22nd, 2004, 12:34 AM   #3
The battery model is the CGA-DU14 (1600mAh) or the CGA-DU21(2040mAh), it's the same battery that fits the N. American GS70.
Tavis Shaver is offline   Reply With Quote
Old March 24th, 2004, 06:12 PM   #4
Go Cycle
If you don't need a lot of power use the CGA-DU07. It it more streamilned. I use that battery configuration with the camera when bicycling as it fits easy in a fanny pack.
<<<-- Originally posted by Tavis Shaver : The battery model is the CGA-DU14 (1600mAh) or the CGA-DU21(2040mAh), it's the same battery that fits the N. American GS70. -->>>
Lou Bruno
Lou Bruno is offline   Reply
