Great Info on Frame Mode vs. Progressive at DVinfo.net
Old January 18th, 2004, 10:06 PM   #1
There always seems to be questions on interlaced vs. progressive vs. frame mode video capture. What are the resolutions in each, compromises, etc.
Here is a terrific white paper (.pdf) from the Panasonic website on these modes. I sure learned something and I hope you will too.
Guy Bruner is offline   Reply With Quote
Old January 18th, 2004, 11:01 PM   #2
Outer Circle
Since it takes me forever to open a PDF file on my computer with 40 megs of RAM, how about giving me the bottom line? Thanks.
Old January 18th, 2004, 11:06 PM   #3
Its the same article by Steve Mullen that was passed around a while back. Still a good read for those who haven't seen it.
Tommy Haupfear is offline   Reply With Quote
Old January 18th, 2004, 11:14 PM   #4
Outer Circle
Oh. Thanks.
Old January 19th, 2004, 12:15 AM   #5
Ooops
Sorry about the duplication. Hadn't seen the previous posts.
Old January 20th, 2004, 06:16 PM   #6
Here you go Frank
Progressive is better than Frame. But you knew that anyway.
michael struthers
www.buzzdigital.com
Michael Struthers is offline   Reply With Quote
Old January 20th, 2004, 07:28 PM   #7
Outer Circle
Yes, I know the difference, and that progressive is a bit better than frame mode. Did you know that Frame mode was invented by Pana? Well, maybe not but they were the first company to put out a cam with frame mode. Also, not all frame mode is the same in the way of quality. :-((
My 2 DVL9500 cams have progressive scan 1/3" CCDs, with BIG 380K total pixels, BIG 360K video effective. :-))
