lens hood at DVinfo.net
Old January 12th, 2004, 02:44 AM   #1
lens hood
does anyone know where i can get a lens hood for a panasonic mx-500 (953) I have checked b&h and haven't found any specifically for my camera. I know that it already has a 'lens hood' but this doesn't work in all situations with some aberations still. anyways look forward to hearing from anyone with any advice
Justin
jlboyle
Justin Boyle is offline   Reply With Quote
Old January 12th, 2004, 08:07 AM   #2
The best deal is to step up the 43mm to something like 52, 55 or 58, then buy a typical rubber hood for the camera.
Yow Cheong Hoe is offline   Reply With Quote
Old January 12th, 2004, 01:25 PM   #3
You could try to make a black rubber lens hood from a toilet plunger. Here's a picture.
Guy Bruner is offline   Reply With Quote
Old January 12th, 2004, 01:51 PM   #4
That's pretty slick, Guy!
How did you attach the hood?
Brandt Wilson is offline   Reply With Quote
Old January 12th, 2004, 03:57 PM   #5
Brandt,
Not my camera...I picked this up on another site. However, the rubber is stretched over the outside of the lens. That's why the cutout is not measured from the mouth of the plunger. You have to cut at a diameter slightly smaller than the OD of your lens housing. In the picture, the lens is the Century Anamorphic, which I believe is a 72mm. I suspect one could find smaller plungers that would work with smaller OD lens housings.
Old January 12th, 2004, 06:29 PM   #6
Outer Circle
Damn. I'll have to start looking at toilet plungers! What you guys would have us do. Great idea, by the way.
Old January 18th, 2004, 11:38 AM   #7
Very cool,
Necessity is the mother of.............you know the rest.
Dave
You cannot motivate the best people with money. Money is just a way to keep score The best people in any field are motivated by passion
--Eric S. Raymond
David James is offline   Reply
