Need help with DV852 UV filter at DVinfo.net
Old December 26th, 2003, 10:41 PM   #1
Hi,
I just purchased a DV852 and Tiffen 43mm UV filter from BH. I try to attach the UV filter to the len but it's not fit. Is the filter screw directly to the len? or I have to get some kind of adapter.
I figure out the problem. I need to remove the hood then install the filter.
Tim Ho is offline   Reply With Quote
Old December 27th, 2003, 12:32 AM   #2
Outer Circle
So you got it on?
Frank Granovski is offline   Reply
