DV852 & Shotgun Mic? at DVinfo.net
Old December 9th, 2003, 11:08 AM   #1
I'm seriously think, about to pick up the phone and call B&H, and order a 852 for $569. Question:
How can I hook up both an XLR shotgun and XLR lav to this camera while shooting a scene, and manually control the mic levels.
Thanks...
dB
Dan Brown is offline   Reply With Quote
Old December 9th, 2003, 11:57 AM   #2
Mic input is stereo minijack only. You'll need an XLR adaptor and probably a phantom power supplier for most shotgun mics.
Cam: Panasonic MX350EN, SOLD my MX8EN
Mac: G3 400MHz PowerBook, 256 MB, OS 9
PC: Pentium 4 2800MHz, 512 MB, WindowsXP
SW: iMovie, Final Cut Pro, Adobe Premiere, Ulead Video Studio, various little utilities
Yow Cheong Hoe is offline   Reply With Quote
Old December 9th, 2003, 03:11 PM   #3
Re: DV852 & Shotgun Mic?
<<<-- Originally posted by Dan Brown : I'm seriously think, about to pick up the phone and call B&H, and order a 852 for $569. Question:
That's an easy one. You have two choices: get a converter (passive or active) or get a mini-plug to XLR converter.
If the mic you plan to buy (model?) is dynamic or self-powered you can go direct with the cable adapter. If it's phantom powered you will need some power supply, that will go between mic and camera.
For the cable adapter you have two choices: a mono cable or a stereo cable. In fact you should get two cables: one mono and one stereo. This is important: if you are using just one mic use a mono cable that sends the same signal to both channels. That is the miniplug is still stereo but the same mic signal goes to both channels.
For more than this information you should go to the audio Forum.
Carlos
Carlos E. Martinez is offline   Reply With Quote
Old December 9th, 2003, 05:57 PM   #4
Outer Circle
Dan, that B&H price is a real steal---and one heck of a 1-chip Pana cam.
For XLR adaptors, you have a few good choices. Beachtek makes one with phantom power.
Frank Granovski is offline   Reply
