GS100 photoshot aufocus sensor at DVinfo.net
Old September 22nd, 2003, 11:31 PM   #1
I my memorys erves me well, there is three
AF sensors available in GS100 in photoshot mode, am I wrong ?
Also, I've noticed somewhere in the past that it is possible to choose manually from these three once in photoshot mode and manual.
So far only one is activated (turning green as AF locked) at the middle upper position of the bracket (AF area ?).
Alex
Alex Zabrovsky is offline   Reply With Quote
Old November 13th, 2003, 06:27 AM   #2
Outer Circle
Alex, I thought I'd bump this up so more GS100 owners can see it, and perhaps give you an answer.
Old November 13th, 2003, 02:42 PM   #3
Thanks Frank, though I apparently resolved the issue already, GS100 doesn't allot manual AF sensor choice - I messed up with Canon cam.
Regards, Alex
