GS100 LCD in recording lighting mode at DVinfo.net
Old September 22nd, 2003, 04:49 AM   #1
Cannot figure how to set the LCD for sibject illuminaiton mode (aside from swapping it to afce the subject).
Can somebody enlight me ?
Regards, Alex
Alex Zabrovsky is offline   Reply With Quote
Old September 22nd, 2003, 10:45 AM   #2
A shot in the dark
If your asking how to turn the LCD lumination on.
First put the camera in 0 lux mode by pushing the night view button two times.
Then flip the screen (as you said) 180 degrees.
Paul Jason is offline   Reply With Quote
Old September 22nd, 2003, 10:48 AM   #3
A shot in the dark
I meant to say( the LCD illumination on:-/)
Old September 22nd, 2003, 12:55 PM   #4
Thanks Paul, will try this tomorrow, just curious how useful is this feature ...
Alex
Old September 22nd, 2003, 01:41 PM   #5
I went out and found a dark place and tried to film a few minutes or so. I could see what I was shooting via the LCD light if I was about three maybe four feet away from my subject. At around five feet it got a bit hard to make out what I was seeing. Things would blur if I moved the camera to fast. Overall it did a good job for no other light than the camera LCD. Down side, you can hurt yourself walking around in the dark:-))
Old September 22nd, 2003, 11:17 PM   #6
I did it on my little daughter slipping this night. Just flipped the LCD, switched to o lux and filmed as she was slipping in so cute pose...
The footage end up brght enough (though shoot from less then 1m) and quite grainy and low frame rate, as expected from 0 lux mode. I do not mind, just to catch the expression.
Regards, Alex
