for Samuel Raj and other GS100K users
I just palced an order for GS100K (black) from Allan and now would be shopping for a bigger battery then the one comes with the camera. I will need the the VBD210 (rated 2000+ mAh) on-camera one.
I was told Samuel (and probaly some other fellows here) have purchased such for just 55 US$ by mail order from Honk Kong. Is that correct ? If yes, would someone be able to point me to this dealer to contact him in regard of that ? Also, are these batteries available in US ? If yes, where and what for ? Regards, Alex |
Alex,
I bought two cga-du21(same as VBD210,2040 mah) from this miraclezone. He sent me with in 4 days. total is $110, including shipping and handling. Its original panasonic battery made in japan. Since its ebay, I cannot guarantee anyone, its on their own risk. I think this guy is reliable. Yes , he sent from HongKong. This battery is available in US from www.bhphotovideo.com, its cost is $99+ and shipping and handling. The link for that ebay. hope this helps... Sam. |
Thanks Samuel, I noted the link.
Is this battery indeed capable for up to 6h of running on GS100K with opened LCD ? Sounds doubtful.... Alex |
Alex,
As you know the manifacturer tricks and marketing always do over the top. If you read the small letters, 6hr is at 20 degrees celsius and consumption of 2 W (i.e. GS50 used with viewfinder) continious recording. GS100 use 5.2 W with LCD monitor, also you will rather zoom, focus, AWB, start, stop, etc., etc. while shooting. Make your calculations! Or see my posts in the other tread for Accessories where I did small test. P.S. It's better to start a tread with more proper name like: Which battery is good for my GS100, or Where to find battery... Or just use the search function of the forum. |
#5 |
VDB210 ratings for the GS100K according to Pany Japan:
Continuous recording without using LCD: 3 hours 15 minutes Continuous recording using LCD: 2 hours 45 minutes Intermittent recording without using LCD: 1 hour 40 minutes Intermittent recording using LCD: 1 hour 25 minutes Note: above ratings are under normal temperature conditions. |
#6 |
Alex,
Bogdan and Allan clearly indicated the exact performance of the battery! Thanks Alan and Bogdan. Hope this info works out for you. |
#7 |
Just to add that my test was playback 1hr and recording 1hr - continious with 1 or 2 rewinds.
I also use Normal for LCD setting (not bright) and do not activate AI (which is a bit too much for my liking). This must save a little bit of power. Despite the 6 hour lable, I think Pana is relatively conservetive (safe) in the numbers pointed out from Allan. I guess normal use is closer to 2 hours for a fresh fully charged battery with my settings for the LCD. Of coarse it depends a lot on the shooting manner. |
#8 |
Thanks a lot guys.
The notes have been taken. Alex |
