Firewire card at DVinfo.net
Old August 20th, 2003, 01:06 PM   #1
Firewire card
Who makes the best firewire card for PC at a good price?
Paul Jason is offline   Reply With Quote
Old August 20th, 2003, 02:49 PM   #2
I bought the Adaptec Duo with 3 USB 2.0 and 2 Firewire connections on one card. Its a highly rated card. You can use pricegrabber.com to find various sources/prices.
Use the following link -
http://www.adaptecstore.com/index.cfm?category=259
Good luck,
Joel
PV-DV953
PC:Dell P4 2.2 120GB
Joel Specter is offline   Reply With Quote
Old August 20th, 2003, 06:46 PM   #3
Thanks Jole for the information. I guess what I should be asking is are all firewire cards the same? Do they just bundled the different ones with different software ? I wish I knew more about this stuff:-/
Old August 20th, 2003, 08:14 PM   #4
All firewire cards are not the same except for basically being a firewire card. Its just like camcorders that range from low to high quality with their features. you have to compare each card and decide whats important.
I chose the Adaptec because of its higher engineering features, i.e. quaility, the additional firewire/USB 2.0 ports, excellant drivers and website support.
Each card does come with different stuff, software, cable etc.
Here is a link to a firewire review use as a example.
http://www.pcstats.com/articleview.cfm?articleID=304
Hope this helps
Joel
PV-DV953
Old August 20th, 2003, 10:23 PM   #5
Thanks for clearing that up for me Joel
