Best tape for GS100K at DVinfo.net
Old August 17th, 2003, 11:42 PM   #1
Who makes the best tape for the GS100K? and where can I get them?
Paul Jason is offline   Reply With Quote
Old August 17th, 2003, 11:47 PM   #2
Outer Circle
I think Fuji makes the best miniDV tape, and I've never had a bad one yet. That's my opinion though.
http://www.dvfreak.com/tape.htm
I live in Vancouver, and here Superstore and London Drugs has the best deals. Depending on where you live, I guess, try our tape sponsor.
Old August 17th, 2003, 11:48 PM   #3
http://www.dvinfo.net/conf/showthrea...threadid=13238
I use TDK, as for as I know, TDK works best with Panasonic gs100k, because the lubricant they use is very similar to panasonic tape.
TDK never gave any problems. Infact i mixed TDK with Maxel, no problem.
Of course Panasonic tape on a Panasonic product, thats a perfect match!
Samuel Raj is offline   Reply With Quote
Old August 18th, 2003, 11:07 AM   #4
Does the Fuji miniDV tape have the memory chip in it? ( IC chip) does it use a wet or dry lubricant? Also, Does the Fuji compare closer to the Panasonic Master Quality tapes or to the Panasonic standard miniDV tapes?
Old August 18th, 2003, 12:54 PM   #5
Outer Circle
Isn't that chip for some Sony cams only? There's no mem chip. Fuji is "dry."
Old August 18th, 2003, 03:42 PM   #6
I have no idea, That is why I asked you:-))
Old August 18th, 2003, 04:12 PM   #7
Outer Circle
Don't worry about the chip. It's for some Sony cams only. :)
Old August 18th, 2003, 06:52 PM   #8
Ok, The chip is out. Now, If I use a panasonic miniDV tape say something like a Professional quality 60-minute DVC (Mini DV) tape, could I still use another type from the same company like a Panasonic 63 Minute Master Quality MiniDV Tape. I can't seem to find any Fuji tape in my local stores. There are lots of Panasonic. If Fuji is a much better tape then I will just buy it on-line. Thanks for all your help!
Old August 18th, 2003, 07:08 PM   #9
Outer Circle
Paul, read that link I gave you. (It's not a good thing to mix tapes.)
Old August 18th, 2003, 07:23 PM   #10
I did read it. I understood it as not to mix tapes of different brands. I thought you just had to stick with the same brand. You are telling me I have to use the same model as well as brand. Right?
Old August 18th, 2003, 08:14 PM   #11
Outer Circle
Right. Not all brand models are the same, plus their formulas change from time to time---not so with Fuji. Fuji comes with always the lubricant. Fuji also makes other high quality media: other types of tape, photographic film, and 35mm motion picture film, to mention a few.
Old August 18th, 2003, 11:47 PM   #12
A big thank you goes out to Frank and the others that gave me input on this subject. I learned a big lesson today. Research all you can, ask all the questions you can and when the day is done just follow Franks advice. At least that's the way this quest took me.
Old August 19th, 2003, 08:06 AM   #13
Hmmm... looks like I've arrived at this thread a little too late.
I've read the dvfreak link previously and remembered that Fuji or Panasonic are the brands to buy. Couldn't find Fuji so I went for Panasonic. There was a 3-pack for around $10 and a single tape for around $6. Naturally, I bought the 3-pack.
So far, I've recorded about 3 minutes on the brand new GS100K with the cheap Panasonic tape. Should I discard the cheap ones and buy the more expensive one? Would it be okay to finish the 3-pack and then switch? Or, since mixing isn't a good thing, would it be okay to just stick with the cheap Panasonic forever?
I just want to take family videos, nothing "professional". The best quality isn't a high priority for me but good quality is. Also, I want to avoid any future problems by getting everything right from the start.
Aylwin Cal is offline   Reply With Quote
Old August 19th, 2003, 10:13 AM   #14
Aylwin,
You'll be laughing but here in Japan the Fujis are cheaper than Panasonic.
I was also wondering and went for TDK - again cheaper than Pana.
I'm not talking for the Pana master grade but I haven't seen in shop the higher Fuji or TDK grade. You can check specs on the makers homepages if you can read a little bit Japanese (katakana).
TDK has slightly better specs than Pana and I do believe them. TDK is old media company (only media and espesially strong in tapes).
Fuji has been top for VHS-C tapes as well.
It's a matter of preference.
In the older analog tape world I've been using always TDK never Pana. But for DV might be different - who knows.
Bogdan Vaglarov is offline   Reply With Quote
Old August 19th, 2003, 01:45 PM   #15
Outer Circle
Here:
http://www.dvinfo.net/conf/showthrea...threadid=13325
Read what Jeff wrote. :)
