how about a used ag-ez30u? at DVinfo.net
Old August 17th, 2003, 01:08 AM   #1
Hey, I was wondering. Since I cannot afford an expensive new cam like a pv-dv953, perhaps I should purchase one of those used ag-ez30u 3 ccd cams. Is this better than my pv-dv702 because it has 3 CCDs? Does this cam have frame mode? Are there any web sites with information about this cam? Help a poor postal worker out people. What do you think? Huh?
Zach Remore is offline   Reply With Quote
Old August 17th, 2003, 01:14 AM   #2
Outer Circle
Here is a AG-EZ30U thread:
http://www.dvinfo.net/conf/showthrea...hlight=AGEZ30U
Old August 17th, 2003, 01:34 AM   #3
Interesting, but I couldn't find anything whether it has frame mode. I also read on that geo city site that it has a bad "DIS." Whatever that is. What is that? It doesn't have DV-in, I also read. I know what that is. I'm not sure now. Do you think my pv-dv702 is better?
Old August 17th, 2003, 01:43 AM   #4
Outer Circle
I cannot answer your questions, except about DIS. DIS is short for digital image stabilization. Your PV-DV702 also has this. Whenever I'm looking for cam info which is difficult to come by, I do a google.com search. As to which is the better cam, I don't know. The 702 is smaller, and takes good stills, and this is what you want with your trip, unless you are also taking a still cam with you. If someone gave me a choice between the 2, I'd lean towards the 702. I rather like that model. Both cams, from what I see, have their pro's and con's. Better sound with the 30U, but lower resolution. Perhaps someone else can answer your questions.
Old August 17th, 2003, 08:35 AM   #5
How about the used DV951 or GS70? You could purchase either one for less than $999.
Young Lee is offline   Reply
