Accessory list for GS100 - Page 4 at DVinfo.net
Old September 17th, 2003, 03:08 AM   #46
Outer Circle
Ahhh, okay. Silver is fine. As long as underneath the silver coat you find solid titanium, like with my SLR. :-)
Old September 17th, 2003, 07:27 AM   #47
Sam, your 607 is even bigger (great price BTW!). The C-500 uses the smaller PH-358 fluid head, but is a black mamba. The next model C-600 uses a PH3-68 head and also a black mamba.
Frank, when you say base plate, do you mean the one the screws under the cam. Yes it is removable (quick release), just like the PH-368.
Allan Rejoso is offline   Reply With Quote
Old September 17th, 2003, 12:11 PM   #48
What are your comments on buying a 2 Way Mini DV Tape Rewinder?
Using this device should save wear & tear on the tape transport. Does it maintain proper alignment after rewind?
Has anyone used a rewinder? Any suggestions would be appreciated?
Joel
PV-DV953
PC:Dell P4 2.2 120GB
Joel Specter is offline   Reply With Quote
Old September 17th, 2003, 02:32 PM   #49
Joel, do a site search on this. There has been a lot of discusson. Some adamantly oppose, some use one religously. I use one for rewinding tapes for either re-use (I do re-use tapes I use for testing) or for storage.
Patricia Kim is offline   Reply With Quote
Old November 12th, 2003, 12:08 AM   #50
Pat. Which model Hoodman are you referring to here? Have you tried it out? Thanks
Peter Warren is offline   Reply With Quote
Old November 30th, 2003, 08:13 AM   #51
Japanese made replacement batteries...
Yesterday I found new source for Japanese replacement batteries for any video or still digital camera.
It will be of special interest of Allan or living in Japan users as the prices are half the original!!!
Check out the big GS100/70 battery offered in silver (or black):
http://www.rowa.co.jp/cabinet/form.cgi?key=72
And the index page:
Bogdan Vaglarov is offline   Reply With Quote
Old December 1st, 2003, 09:46 PM   #52
Outer Circle
Allan, thanks. Yes, I meant a quick release plate.
