Help with Metadata at DVinfo.net
Panasonic AVCCAM Camcorders
Old April 26th, 2013, 10:16 PM   #1
Help with Metadata
I've never been able to view my metadata in premiere pro, I use avccam viewer to create meta files on a dedicated sd card; insert the card, select read from card in the menu; try to remember which file I'm wanting to use as they all say Scene 1,2,3 ect not the name I saved them as on the comp. There is also no way to read or alter the meta on the camera which is frustrating; then after all this I load the files onto my drive using avccam viewer but no meta. Am I missing something here? I have to send my cam in on warrantee unrelated so I'm hoping that will fix this also but just in case I want to check with the users on here, thank you.
Ryan Cool is offline   Reply
