Audio Hook Up at DVinfo.net
Panasonic AVCCAM Camcorders
Old March 26th, 2013, 06:29 PM   #1
Audio Hook Up
What do I need to get a line level signal from a Roland R-44 into an AG-AC160A? Is the only route in through the XLR mike inputs, set to line level? If I just want a good quality mono feeding into the camcorder is this the way to do it?
Wedding and Events Videography
www.video-vermont.com
Tim Palmer-Benson is offline   Reply With Quote
Old March 26th, 2013, 09:32 PM   #2
Re: Audio Hook Up
The R-44 only has line outputs on RCAs, so you'll need an RCA to XLR cable. They're not hard to make, and they're cheap to buy. You might also want to get a dual RCA to single RCA y-cable, to combine the signals into one mono signal.
Edward Carlson is offline   Reply
