Double shoe on HMC150 for Accessories at DVinfo.net
Panasonic AVCCAM Camcorders
Old June 26th, 2011, 04:21 PM   #1
The HMC-150 is a great camera but sure could use extra shoes on the top for lights and wireless receivers. Has anyone got a line on where to find something to add extra shoes to the standard one?? Even my AGC-10 had 2.....
Ray Larson is offline   Reply With Quote
Old June 26th, 2011, 04:59 PM   #2
Re: Double shoe on HMC150 for Accessories
You can use the Pearstone Accessory Shoe Adapter w/ 1/4-20 Stud Connector which fits on the additional 1/4-20 hole on the handle of the HMC150
Pearstone Accessory Shoe Adapter w/ 1/4-20 Stud 9041680 B&H
Or you can get a simple rycote shoe extension bar on the cold shoe of the HMC150
http://www.bhphotovideo.com/c/product/770017-REG/Rycote_37705_HOT_SHOE_EXTENSION_20cm_w_HS.html
Allan Tabilas is offline   Reply With Quote
Old June 29th, 2011, 05:43 PM   #3
I got one of these as a gift...
N R G R E S E A R C H
but I see B&H and other vendors now list them as no longer available. However the manufacturer has them listed on its' web site.
I've used it on my HMC with a Smith-Victor SV-840 and a LitePanels Micro Lite, with both mounted at the same time. Quirks include these:
- with the barn doors on the S-V open, they're wide enough to interfere with the Micro
- any accessory puts weight up there, making the cam more prone/sensitive to any vibration
- with a tripod on a dolly, the screw-in shoe has worked loose when moving the rig over uneven flooring, e.g. tile floors with wide grout lines, and parking-lots. (I suppose a rubber washer of some type might help, but I haven't made a point of getting one and making it fit)
- when I first got it, EVERYTHING was a tight fit. I bought a set of slim-line files and filed each receiving groove every so slightly, and now things slide in/out much easier.
It's acceptable if you're not moving the rig from place-to-place. Just be ever-mindful that the rig will be more sensitive to any vibration.
Denis
Our actions are based on our own experience and knowledge. Thus, no one is ever totally right, nor totally wrong. We simply act from what we "know" to be true, based on that experience and knowledge. Beyond that, we pose questions to others.
Denis Danatzko is offline   Reply With Quote
Old June 29th, 2011, 05:50 PM   #4
i always recommend these: DM-Accessories — UNI-CUBE - multi-point mount for universal shoe mounts
i use one and i can attach up to 5 accessories if needed
Iker Riera is offline   Reply With Quote
Old June 29th, 2011, 07:30 PM   #5
For my wireless receiver, I use
a "Jimmy Box" Large size for my A-T 1800 series receiver. Jimmy attaches to bottom of cam, then plate attaches to bottom of the Jimmy.
But it cost a lot more than any of the options described here.
Denis
Old July 2nd, 2011, 12:43 PM   #6
Got the Pearlstone adapter and it seems to be working just fine. Thanks all for your suggestions. Surprised multiple shoes were not engineered in. Oh well
Old July 2nd, 2011, 01:46 PM   #7
In the event anybody else looks for such a device, I can never recommend this guy's gear enough:
The J-Rod & J-Cube Microphone and Accessory Mounts for DSLR and Video Cameras
www.mcbob.tv
Kevin McRoberts is offline   Reply With Quote
Old July 4th, 2011, 11:37 PM   #8
Well, it effectively is engineered in. The 150 does have a threaded hole on the handle to mount all manner of toys on, along with the cold shoe on the front of the handle. I use a bracket by NRG that allows me to mount 3 Sennheiser wireless mic's at once. Not a problem.
Steve Wolla is offline   Reply
