wide angle lens for HMC-150 at DVinfo.net
Panasonic AVCCAM Camcorders
Old May 8th, 2011, 11:29 AM   #1
Do any of you use a wide angle lens adapter for the HMC150? I'm considering one but I realize the original lens is already quite wide. And I'm worried about barrel distortion. Do you have any recommendation for WA lens adapters with minimal barrel distortion? I'm considering:
http://www.bhphotovideo.com/c/product/626889-REG/Cavision_LWC07X72E_LWC07X72E_Two_Element_0_7x.html
or
http://www.bhphotovideo.com/c/product/624187-REG/16x9_Inc_169_HDWA6X_HPX_169_HDWA6X_HPX_EXII_0_6x_Wide.html
I'm leaning towards the 1st one because you can zoom thru 90%.
Gregory Lee is offline   Reply With Quote
Old May 13th, 2011, 12:26 AM   #2
Re: wide angle lens for HMC-150
Hmm, I guess not many people use a wide angle lens adapter for the HMC-150.
Old May 13th, 2011, 02:12 AM   #3
It has a very wide lens anyway.
Even doing weddings in small houses and rooms I've never felt the need for a wider angle.
Cheers,
Vaughan
Vaughan Wood is offline   Reply With Quote
Old May 25th, 2011, 06:06 PM   #4
Hi Gregory,
I use two adapters with the HMC150, a .6 and .4. Here is a review I did.
Von Real
I see you are in Norman. We are over in Tulsa. Small world. What kinds of videos do you produce?
Mark Von Lanken
www.VonWeddingFilms.com
Mark Von Lanken is offline   Reply With Quote
Old May 25th, 2011, 10:32 PM   #5
Century Optics are very nice (and expensive) lenses. I used to use one with my DVX-100. If I get one with the HMC-150, I'm hoping that the 72 mm bayonet mount would be compatible with future camcorders if I upgrade. But I noticed there are a number of different brands out there, many of which are a lot cheaper. Since barrel distortion is inevitable, I might try one of the cheaper brands and if I don't like it, I'll return it. Something tells me, I'll probably get blurry edges and vignetting :(
Thanks for the video reviews though. (btw, I'm surprised the 1.6x telephoto has that much vignetting on the Century Optics)
Old May 25th, 2011, 10:51 PM   #6
Originally Posted by Mark Von Lanken View Post
Hi Gregory,
Von Real
Dabble in event videography. We're just 2 hours away from each other; And and I'm from Australia originally (Brisbane), which is two hours (by plane) from Melbourne.
Old May 27th, 2011, 03:49 PM   #7
Hi Gregory,
You are welcome. Boomer Sooner!
When I shot in SD I used $100-150 wide angle and fisheye lenses, but when I went to HD, I bit the bullet and went for more expensive glass since HD has higher resolution.
One of my shooters had a wedding over in Norman just last weekend.
Mark Von Lanken
