TM-700, Transferring files to Camcorder at DVinfo.net
Panasonic AVCCAM Camcorders
Old March 29th, 2011, 02:47 PM   #1
Is there a way to put native TM-700 video files from my PC hard drive BACK to the camera for video playback?
Currently the only way I have to play the beautiful 1080p/60 footage from my TM-700 is through the camera itself. The computer I have is too underpowered to play it without skipping.
I transferred the full contents of my SD card and camcorder drive to my PC before realizing that it can't go the other direction.
Patrick
Patrick Stark is offline   Reply With Quote
Old April 6th, 2011, 02:14 PM   #2
Re: TM-700, Transferring files to Camcorder
Nothing? .
Old April 6th, 2011, 02:28 PM   #3
Hi
::: multiAVCHD home ::: might be able to, it has the option.
Regards
Phil
Phil Lee is offline   Reply With Quote
Old April 7th, 2011, 08:05 AM   #4
You can put the STREAM files back but the cam writes other files it needs to find and display them.
If using separate sd cards isn't an option for each recording session, then create a folder on your hard drive for each session then copy the ENTIRE sd card contents into it.
Erase the SD card then copy all the files you just copied (including directory structure) back to the SD card.
Walt Stagner is offline   Reply With Quote
Old April 7th, 2011, 11:37 AM   #5
Thanks for the responses.
Old June 9th, 2011, 07:17 AM   #6
Panasonic's AVCCAM Viewer will
https://eww.pavc.panasonic.co.jp/pro...htm#avccamvmac
www.mcbob.tv
Kevin McRoberts is offline   Reply
