Simultaneous video outs at DVinfo.net
Panasonic AVCCAM Camcorders
Old March 1st, 2011, 12:34 PM   #1
Planning on big interview studio shoot with AF100 this weekend. DP is bringing his Small HD montior, with HD/SDI in. Thing is, he wants to mount that on camera for focus assist - and I doubt I'll always be in a position to see it. So I need some kind of client monitor. Typically I use a really cheesy but effective DVD clamshell monitor with composite video in. All I really care about is framing. Wondering if I can get simultaneous SDI and composite video outs with the AF100? Or maybe there's a better solution.
Thanks, Nick.
Nick Ravich is offline   Reply With Quote
Old March 1st, 2011, 05:14 PM   #2
Re: Simultaneous video outs
Nick,
These things might be able to help you figure out what you can do. You might want to get an HDSDI splitter and a second HD monitor. Not clear if there is a composite out separate from the SDI.
Check out this link to get a manual if you don't have one
Operations Manuals for the AG-AF100
Page 43 from advanced PDF about AF 100
E
d
it
in
g
When outputting video and audio signals from the camera to an external device, connect to the
input terminals of the external device.
Use a double-shielded HDMI cable (not included).
It is recommended that you use Panasonic’s HDMI cable.
This product is not compatible with VIERA Link.
Limitations of image output
When using SDIOUT output, side LCD and EVF cannot be operated simultaneously. In order to perform
simultaneous operation, set the SDI OUT on the settings menu AV IN/OUT SETUP to OFF. When the
EVF MODE on the settings menu DISPLAY SETUP is set to AUTO, EVF disappears upon opening/
closing of the LCD.
No HDMI output is performed when REC FORMAT is set to 1080/24p and SDI 24Ps is set to ON.
When SDI&HDMI OUT SEL is set to DOWNCONV, SIDE CROP is disabled in the DOWNCON MODE
settings, and SQUEEZE is enabled automatically.
Some displays, such as time code display and audio level meter display may not be visible on the videos
output from the VIDEO OUT terminal.
Old March 2nd, 2011, 07:15 PM   #3
Thanks Daniel.
