HMC40/80 Modes and Sharpness???
Hi All
Having upgraded from the HMC70 which shoots 13mbps as the highest mode, I did a wedding with the HMC80 in HG mode so the footage would sorta match the HMC70 as the 2nd camera. What I wanted to ask is that even in HG mode (13mbps) the video from the 80 is pristine!!! For you guys with the 40 (or 80) is the 24mbps highest mode on the camera really worth it??? Is there a huge difference in maybe sharpness or something else.... in PH mode on the 80 it eats SDHC space up twice as fast (almost) so I'm really interested to know if the footage is visually a lot better than at 13mbps?????? Comments be be much appreciated as my 2nd 80 arrived yesterday and so I'm doing this weekend's wedding with the two new cameras. If PH mode is the way to go and makes a big difference then I also will need some bigger cards!!!! Chris |
Re: HMC40/80 Modes and Sharpness???
Hey Chris ,i always shoot ph 24mb/s ,why not?
it does take up more space ,but why limit yourself when you have the ability to shoot higher bit rates |
Thanks Tom
I agree shoot at the best rate possible but what are the advantages exactly....more pristine footage ???? I don't seem to find anyone who can say "When you shoot at 6mbps ..... the footage will ...... BUT shoot at 24mbps and you will find that .........." Any technical reason why we need to shoot at the highest bitrate we can ????? Chris |
Hi
Higher bit-rate is better, leading to less compression artefacts in complicated scenes. Lower bit-rates can look just as good until they are faced with a challenge, so you are better off always using the highest rate. Regards Phil |
#5 |
I always think in terms of how much processing will be involved in post . . . when you're doing things like color correction, effects, rendering, converting, etc., you will always get a better result when you're starting with the best quality and most amount of data possible. This includes routine things like converting for DVD/Blu-ray or web delivery.
#6 |
Thanks to you both
PH mode it definately is then. I will grab a few extra 16GB cards this week as well to allow for the extra space needed. Chris |
