TM-700 - Internal memory or SD card?
Would the built in memory be more reliable than using an SD card? Just curious.
I would think so in a theoretical sense but probably not measurably. Why do you ask?
Had a discussion with a friend who insists the built in memory would be more reliable than an SD card. I figured they may be equal in reliability, assuming one is using a name brand card. Just wondering what others would think.
Well that's true, it could be unreliable if you put an unreliable card into it. But I don't think it's necessarily unreliable by definition.
#5 |
No doubt there is some risk of damaging contacts etc with continued insertion and removal of the card.
I was wondering whether it is possible to record on both the built-in memory and the SWd card at the same time in either the TM700 or the TM 900? |
#6 |
Hi
You can't record to both at the same time. Regards Phil |
#7 |
I just had a card fail and everything on it was lost. Fortunately I had already backed up the file. I've never had a problem with the internal memory.
FWIW |
#8 |
Thanks Phil, I suspected that there would be no parallel recording but there is no harm in hoping.
Kirk has reminded me that I have had an SD card irretrievably fail. |
