Viewfinder images very dark! at DVinfo.net
Panasonic AVCCAM Camcorders
Old February 16th, 2011, 03:02 AM   #1
Hello all
Picked up an AF101 yesterday at the BVE show. After trying it out briefly, I noticed the LCD screen on the side of the camera is a decent quality - but when you close it and try to use the viewfinder on the back, the image is so dark - too dark to work with. Has anyone else had this issue, or do you think it may be a problem with my camera?
Maybe I may be better off buying something like a hoodman for the LCD screen so I could use it in bright conditions?
Thanks, Sparky
www.sparkymedia.net
Mark McCarthy is offline   Reply With Quote
Old February 16th, 2011, 07:25 AM   #2
Sponsor: Westside AV
Have you tried showing bars and then adjusting the VF and LCD.
I do this every time I the location or light changes.
And no I have not noticed the VF being dark. I find it to be quite good.
Let us know if your problems continue even after adjustment.
Old February 16th, 2011, 04:59 PM   #3
The EVF can be set exactly the same as the LCD.
Sounds like someone was playing the camera before you picked it up!
Cheers,
Vaughan
Vaughan Wood is offline   Reply
