#76 |
So there mushing (technical term) a 12MB matrix into a 1920 x 1080 2MB matrix, as with DSLR. But apparently with a heavier low pass filter, as well as other electronic magic. The camera has the advantage of not needing to make very high res still photos.
It may not be the exact chip in the GH2, but I bet it's very close. It makes me wonder how good a purpose built chip will be? Does a purpose built chip even need to be bayer? Is the AF100 bayer? |
#77 | |
Why does it worry you? With the right OLPF, pixel skipping is not the problem it is in DSLRs. The worst implication is likely to be reduced sensitivity compared to if it wasn't used. I suspect that is why it doesn't seem to be anything like as noise free as the F3 seems to be. And that is likely to mean the lack of 10 bit doesn't really matter, 10 bit only means a lot in a very noise free camera, so whilst the F3 may well benefit from it, the AF101 probably won't. |
#78 | |
My current workflow is Sony EX1 Letus adapter and 35mm still lenses using the 10 bit out to a Ki Pro editing in vegas by proxy and colour correcting and rendering in 32 bit DPX files in After effects. This maintains the highest quality. My interest in what the AF100 can do is would it be a step up or a step down and so I'm trying to evaluate what it can do here in this forum as I expect are many others as I and most people cant afford to just buy one and then decide. |
#79 | |
Sponsor: Westside AV
Mark, I use an EX1R and an EX3 with NanoFlash. I also Have both AJA Kona and Matrox MX02 in my edit suites. I have captured 10 bit into my Kona from SDI in the EXcams, for chromamkeys. And now that I have been using my NanoFlash for more than a year, I have not noticed any huge difference in chroma keys 8bit (NF) vs 10bit (Kona). I think the EXcams are fairly noisy so the benefit of 10bit is IMHO not great. The 422 color space is a significant upgrade though. I don't think you will really have an answer if the AF100 is an upgrade to your SDOF until we have some more footage available. And more testing has been done. I do think it will be a lot more ergonomically workable than a ground glass adaptor on an EXcam. I have ordered the AF100 and I will be doing a lot of comparos EXcams to AF100. And I will post my findings here. I hope personally to be able to mix EXcams and the AF100 in my productions the way I have done with my 5DmkII and 7D. I really see the AF100 not as a replacement for my EXcams but a much better 7D. I think even with all its problems the 5DmkII is still in a class of its own. I love shooting with it, the 7D not so much. These are my personal feelings and observations, your "smilage" may vary depending on your shooting style and clients.
Olof Ekbergh • olof@WestsideAV.com Westside A V Studios • http://www.WestsideAVstore.com/ |
#80 |
Thanks Olof
I'm looking forward to seeing some of your findings! Best Mark |
